RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Whats the difference between surface and air servos? (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/9028358-whats-difference-between-surface-air-servos.html)
crashland 73 08-19-2009 12:21 PM
I have some surface servos that I use in my airplanes. I was wondering what the difference was? I think I might have done the opposite in the past too, air servo in surface vehicles. I dont mean the torque value either.
mrbigg 08-19-2009 12:31 PM
RE: Whats the difference between surface and air servos?
I've used Airtronics 102 servos in the air and surface and never a problem. Some brands label for each use, but why I don't know. Waste of time.
Druss 08-19-2009 12:38 PM
I know that some servos are not recommended for helicopters above a certain size due to vibrations. Other than that you can use them interchangably as long as you have the speed and torque you want.
crashland 73 08-19-2009 12:50 PM
thats what I was wondering. i guess they just do that to make more money to folks that figure one is for only one type.
P-40 DRIVER 08-19-2009 03:43 PM
vibration issues is normally why servos has restrictions.
crashland 73 08-19-2009 03:46 PM
i dont guess i see what you mean.
JohnW 08-19-2009 10:58 PM
Some of the servo's I've seen marketed for surface application have an extra o-ring seal by the output shaft compared to thier aircraft equal. I'd assume this would be to help prevent dust/water etc from entering the servo, which typically isn't an issue with aircraft/helis. Other than the seal, I've never noticed a diff and have used them interchangeably as others have posted.
