JR 791 & RT88 retract servo dimensions?
Can anyone provide the mounting hole center point dimensions for the JR791 and RT88 retract servos. (for comparison the Hitec HS-75 is 12mm center width and 51mm center length) I am preparing a material list for the new H9 P-51 and in my view the retract servo is going to have to be darn near identical to the one specified (RT88) if it is going to mount and fit properly. The problem is that I cannot find the servo dimensional information on the JR website - it gives outside dimensions but not mounting hole center info.
Does anyone have experience with either the JR791 or the RT88? thanks Howard |
RE: JR 791 & RT88 retract servo dimensions?
I found the 791 to be a drop in replacement for the hs75 on my H9 P-40.
Edwin |
ORIGINAL: Edwin I found the 791 to be a drop in replacement for the hs75 on my H9 P-40. Edwin For clarity, the mounting holes and height, etc, all are just about the same is that what you are saying. On the new P-51, the servo has to mount on what is essentially a small plastic, pre-drilled, servo tray that is part of the retract mechanism. Thanks Howard |
1 Attachment(s)
I found these in the latest Japanese Catalogue.
CustomPC:
Now that is helpful thank you very much. This is exactly what I needed.:D Howard |
