Programming Eclipse 7 for delta wing
I'm having trouble mixing channels 1 & 2. I have "elevons" active, but the aileron function moves the wrong direction. when I reverse it, it shifts to elevator. When i reverse the elevator channel, it goes back to ailersons (in the wrong direction.) I've tried all combinations. Anthing simple I'm not doing??? Anyone?
RE: Programming Eclipse 7 for delta wing
Not positive but have you tried using 1and 6 instead of 1 and 2 .. Also ther is a $12.00 dollar mixer you can purchase if no luck here ...
Channels 1 & 2 are correct per the manual. You can download the manual[link=http://www.hitecrcd.com/pages/support/48]HERE[/link] .
The setup for elevons is on pages 24 & 25.;) |
ORIGINAL: dkalins I'm having trouble mixing channels 1 & 2. I have "elevons" active, but the aileron function moves the wrong direction. when I reverse it, it shifts to elevator. When i reverse the elevator channel, it goes back to ailersons (in the wrong direction.) I've tried all combinations. Anthing simple I'm not doing??? Anyone? 1. Set both servo reversing switches to Normal, and start again with Left aileron in Ch1, Right aileron in ch 2. Ensure both horns either face toward the fuselage or both horns face out toward the wing tips. If not then operating correctly - 2. Swap the servo leads to the opposite pins. AOK = good . NOK> 3. Swap leads back to orignal pins and reverse switch ch 1, if NOK reverse switch ch 2. If still NOK switch ch 1 back to Normal. AOK = good. NOK> 4. Swap servo leads to opposite pins on Rx, retry and then in need, reverse switch ch 1, if NOK reverse switch ch 2. If still NOK switch ch 1 back to Normal. AOK = good. <span style="font-size: smaller">[ Do not use Hitec servo on one side and a Futaba on other as they rotate opposite directions and can be a PITA to set up as a pairfor elevons.] </span> Regards Alan T. Alan's Hobby, Model & RC FAQ Web Links |
| All times are GMT -8. The time now is 12:05 PM. |
