Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC On Road Nitro Cars
Reload this Page >
Fuel won't flow and can't prime NITRO BUGGY
RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Old 01-29-2020, 06:10 AM
needhelpplease
Exclamation Fuel won't flow and can't prime NITRO BUGGY
So I have an HSP 1/10 scale warhead buggy and I haven't used it for about 5 months. I tried to get it going but I couldn't prime the buggy to get fuel into the carb. The only way I could move the fuel to the carb is by blowing into the tube that is connected to the exhaust. When I do this I am able to start the buggy and it runs for about 5 seconds with barely any smoke then dies down because no fuel is getting to the engine. It also gets VERY hot. To get it going again I would have to blow into the fuel line to move the fuel so it can run for another 5 seconds. My fuel lines are fine but it is quite loosely attached to the exhaust pipe due to the way the whole is structured. My exhaust gasket is broken but I tightened it pretty tight so I think it should be fine. Does anyone know how to fix this problem so I can prime my car and also get fuel flowing to the engine?
Thanks so much for your help.
Old 01-29-2020, 01:22 PM
1QwkSport2.5r
1QwkSport2.5r's Avatar
Low speed needle is probably WAY too lean.
Old 01-29-2020, 09:13 PM
needhelpplease
Also I can get the fuel to flow if i over the carb hole and full the trigger without putting my finger the exhaust hole. So I think the main issue is that my exhaust isnt creating enough pressure to push the fuel into the carb. Any further tips?
Old 01-29-2020, 11:27 PM
1QwkSport2.5r
There is no muffler pressure during starting or idle. Look, if the engine cannot draw fuel beyond the prime, but it can be primed, then you need to look at what limits fuel flow at idle in the carburetor. One way to confirm this is blow into the pressure line with carb at idle. While still blowing into the line, open the throttle wide. It should flow easier. Now, open the idle needle 1/2 turn and see if it flows easier with the throttle at idle.
Your problem comes up quite often. Quite often, the problem is either too lean or idle mixture, too small of an idle gap, or clogged carb. Since you can get fuel to go through, I doubt the carb is clogged. Iím guessing itís just too lean.
Old 05-28-2020, 01:24 AM
J7777B
Hi, I wonder if you could help me.
My nitro car won't prime by the traditional ways the only way can get the fuel to the carburetor is to blow the pressure pipe and hold the throttle. The engine then can start for a bit and die.
Is it because the LSN too lean? Or please advice
Old 06-07-2020, 07:20 AM
Big Alice
Replace your broken exaust gasket. Your exaust pressure is leaking and not pressurizing your fuel tank That's where I'd start..
Old 06-09-2020, 01:15 AM
Richard-V
which engine do you use?
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
