RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Nitro Car Motor problems?
Old 04-30-2020, 10:17 AM
mark87
Default Nitro Car Motor problems?
Hi everybody, im new to this hobby and i have a kyosho inferno mp9 tki3, since i have changed the differential oil and messed the carburator setting and reset the setting on the transmitter i have a lot of trouble of getting the motor to run. I reset the carburator to the stock setting. HSN 3,5 turn counterclockwise from closed position, the LSN flush to the carburator and the idle screw so that there is a 1mm gap. Sometimes i get the morot to run but it has okward behavior, the wheel start to spin in idle, if i hit the brake the morot will stop running, sometime i notice that when i try to switch on the motor on a starter box the wheels spin accordenly with the spinning of the starterbox wheel. Maybe a clutch problem? What should i do?
Old 05-07-2020, 11:37 PM
Zeelott
How is your throttle trim on your remote? Sometimes it can be the simplest things. When was the last time you put new nitro fuel lines on it?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
