RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
V-one RR gearing help
Old 11-25-2003, 02:48 AM
poosack
Default V-one RR gearing help
Hi everyone. I have decided to upgrade my gearing on my V-one RR.
I'm am going to upgrade. 1. the belts. 2. upgrade to alloy pullys. 3. pinons and spurrs.
What gearing should i chose that will give me faster top end and good acceleration without giving my .12TR to much hassle. Since i am buying form towwer hobbies i have these options. I am only going to upgrade the two pulleys that the main belt goes onto.
1. belts - front belt- 210 rear belt - 192, middle belt - 375
2. pulleys - 18T, 19T, 25T and 27T
3. pinion's - first gear - 16T, 17T, 18T second gear - 19T, 20T, 21T, 22T
4. spurrs - first gear - 48T, 49T second gear - 44T, 45T
Wat do u guys think would be my best gearing combo cheers
Old 11-25-2003, 10:40 AM
Nitroaddict
Nitroaddict's Avatar
Default RE: V-one RR gearing help
stay with the stock pulleys - they are the best out there. also stick with the stock spur gears. I run a trinity reflex, which is basically the same car as a V1RR. I run a 16/19 pinion set on small tight tracks, and 18/21 on larger tracks. i wouldnt go any higher than a 17/20 on the OS .12TR, since it lacks the bottom end power needed for anything higher.
Old 11-25-2003, 11:51 AM
dg2b
The V1RR comes with plastic pulleys in stock form, in which the Reflex comes stock with alloys. You can underdrive the car by playing with the spurs. I can't remember my numbers now but can check tonight and post. Nitroaddict's number sounds right though.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
