problems with rs4
problems with rs4
i got my 4sr like 4 months ago and it was runing fine until the problems started first the car turned slightly left and was harder to control i couldnt figure out wat the problem was i could realy use some help
and the clutch bell keeps on ringing and when i tighten the screw i run it and after 5 tanks of gas it starts ringing againi could realy use some help
RE: problems with rs4
sorry to tell you but you wont find a way to go straight every time with this car (at least I couldnt)
You can put some bearings and it may get better
Also the steering servo and its saver are really bad you could buy another with metal gears
I had the same problem with mine. At low speed it would go straight and the faster it went the more it would pull left.
I ended up taking the front and rear diffs apart and relubing them. This ended up working, but I am not sure if it was the diff work that fixed it or just taking the whole car apart that solved the problem.
One simple suggestion is to make sure that none of your wheel nuts are too tight. This can cause some binding on the wheel.
Good luck.
Good luck.
