Your NTC3 stalls? Please read
I notice every single time i put my body on my NTC3 and then try to accelerate the engine quits. Why? Even if i just place it on the car with out securing it the engine quits. The engine does not even idle long plus the mixture is set correctly. Please help
RE: Your NTC3 stalls? Please read
yes only with the body on. There are holes cut out too. One in front, one in the back and one on the side.
if the engine doesnt idle long, then either the mixture is NOT set correctly or you have a bad glow plug. check the plug first, and if its okay, then u will need to adjust your LSN and/or the ISS.
Well,
If its only with the body, the maybe your body is doing one of the following:
1) air filter is blocked? (fat chance)
2) fuel lines are being pushed against a hot surface or being cut off
3) some servo-body binding proble? (not exactly possible but I thought I could throw it in there)
4) This may sound funny.. but make sure all your CARB SCREWS are there and that they are tight.
Maybe your body is shifting your carb and because its missing a screw.. you have a major air leak with the body on? (happened to me)
ram
ram
