RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
tuning 2needle for newb
Old 12-07-2003, 10:37 PM
raceme
Default tuning 2needle for newb
this is my first engine with two adjustable needles. its a .15 fantom engine pull start. heres the problem. i can start the engine when the throttle is half open then right when i start to close it. it cuts off. my carb it set to open 1mm when closed. do i richin or lean out the low speed needle a bit or richin or lean out the high speed needle. or both.??????????
Old 12-07-2003, 10:59 PM
z style
Default RE: tuning 2needle for newb
is yoru high speed needle factory set?
Old 12-07-2003, 11:12 PM
raceme
yea
Old 12-08-2003, 12:07 AM
proptop
My Feedback: (8)
proptop's Avatar
Sounds like maybe the lo speed might be too lean...Try opening it a quarter turn and see what happens. You might want to check how far it's open first and write that down. Close the carb. arm down completely, and gently turn in the lo speed screw until it "lightly bottoms out" (stop when you feel just any resistance, cuz if you turn it in too hard, you can damage the end of the needle, or the seat) Then turn it back out the number it was open + 1/4 and try running it . If it wants to stay running a little longer, you're on the right track. Seems like there should be something in the instructions about the # of turns...Prob. should be something like 1 to 1 1/2 open, but they're all a little different...
Old 12-08-2003, 01:26 AM
raceme
yea i do feel that resistance in the low speed needle thanks for tellin me that. ive been turning it past that point then turning out . ima test that out tomorrow
Old 12-08-2003, 01:30 AM
raceme
how do the needles acually work. they restrict fuel from coming in. high speed needle comes to play when you go high speed i know that
