WILL NEW FANTOM 12 FIT AN NTC3?
ON, CANADA
RE: WILL NEW FANTOM 12 FIT AN NTC3?
if i remeber right the NTC3 uses a SG crank or a Short threaded, which in that case yes. you may want to wait for the .12 RE engine which comes out in Jan
NY
I'm checking now, but I'm pretty sure it's a sg crank. If you get it, let me know how it is. I looks like a pretty good pullstart engine. They have one on e--y for cheap.
If your going to put it in a NTC3 RTR then you will need the SG shaft version. If you want a slide carb and you have the RTR then you can go on AE's website and it tells you how to convert the stock linkage to use a slide carb. The RTR manual doesn't tell you how to set up a slide linkage[&:]. Other then that the engine should drop right in.
WA
The best kind of engine is a SG crankshaft with a slide carb. They're VERY easy to install and setup. The only thing you'll need at most is a new clutch nut. The stock throttle/brake linkages will work fine for either carb, you will just need to modify it a bit.
