Compagnucci Super Beetle / F1: Nitro and/or Gasoline
#234
Much more faster accelaration and better rpm.The original compagnucci gearbox is 3 speed. I will upload a photo. I made this box from serpent gears,clutch and made the shafts on a lathe.
#242
Does it make a difference to the power ?
Thanks does the manifold come with it I searched but can't find it
#243
Yes it makes the power band wider without any loss at the bottom end. Rev range improves a lot, I tried a lot of tuned pipe from other makes and didn't see improvement but this dynamite tuned pipe is like a booster.
#246
Hi, if you search on ebay to find this type of manifold from serpent all you have to do porting to the face of the manifold, put the gasket of compagnucci on it to mark it and grind off the metal.
