Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC On Road Nitro Cars
Reload this Page >
RS4 Tranny prob, not switching to second!
RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Old 08-22-2005, 11:40 AM
Mchwind Chimes
Mchwind Chimes's Avatar
Default RS4 Tranny prob, not switching to second!
Well usually when you have this problem you would tighten up the screw that is on the hub (silver thing by the pinions) but theres no screw, is a clutch holder set the answer to the problem, all i need is the ball and spring, but the recomend the whole clutch holder set.?
Old 08-22-2005, 11:43 AM
Mchwind Chimes
Default RE: RS4 Tranny prob, not switching to second!
Please let me know
Old 08-22-2005, 02:04 PM
Burntt32
ok, im assuming you have the same problem that i did as did many many many others. the middle ring of the silver thin on the 2 speed is spinning freely. to tighten this and make it spin with the shaft you must tighten down the VERTICAL setscrew. if you tighten the diagonal one you will adjust your shifting point.
Old 08-24-2005, 12:36 AM
goodtimes
My Feedback: (53)
Check this out. http://hpiracing.com/graphics/instr/...-2%20P2_A4.jpg. When I got my rs4 it was assembled wrong so it wouldn't shift. Now it works great but need to change my pinion and sur gears since the previous owner had stripped them...
Old 09-01-2005, 06:44 PM
Mchwind Chimes
Is that vertical screw also called a ball and spring?
Old 09-01-2005, 09:30 PM
Burntt32
no that vert screw is called a set screw. and if its not there...then that would be your problem
Old 09-02-2005, 07:06 AM
BUGGIES_R_US
BUGGIES_R_US's Avatar
Yea thats very likely.
So the tranny is shifting.. but the second gear pinion isnt attached to the shaft (set screw's job) so.. no power transfer!
ram
Old 09-02-2005, 10:22 AM
Burntt32
exactly.
and my tranny is havin some more problems. re-built it twice already. think im just gonna buy a new one. shifted into 2nd for the last time with this one yesterday. pushed it a little too hard, doesnt shift and a second after the shift point it makes a hard 90degree without my input and lands one a curb.
Old 09-03-2005, 06:02 PM
lordcontrary
This thread seems to apply to me as well and I have a related question...
...my rs4 shifts... but I'm just not sure how to judge WHEN it should shift... my opinion -I think it shifts too late... when it does shift I estimate it adds maybe 15% more top speed capability ( opposed to staying in 1st ).
If my low speed set screw ( engine carb ) is adjusted wrong will this also effect the 2nd speed shift point? ( my logic being the engine has too little power/torq at the low setting... )
I'm a newbie, a yes or no would explain a couple different things to me.
Old 09-04-2005, 09:23 AM
Mchwind Chimes
My tranny isnt swithcing at all. So i think its stuck in first because it doestnt have the ball and spring that goes in the silver hub
Old 09-04-2005, 12:03 PM
C3Racing
Maybe this it what you need? http://www2.towerhobbies.com/cgi-bin...?&I=LXM583&P=0
Old 10-08-2005, 10:56 PM
Mchwind Chimes
I put a heavy duty tranny in yesterday, its running hard!!
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
