air filter question
FL
air filter question
i recently bought a motorsaver air filter for my car but when i put it on my car isnt geting to its top speed so my question is how can i make the filter let more air flow or should i just put the stock filter back and forget the new one
RE: air filter question
To be honest i wouldnt say its the air filter. because the engines only suck small amounts in anyway. but i wud just lean the engine abit more.
FL
Yah, unless the air filter tube is getting pinched, the carshoudl run fine. You do realize that engines dont hold there tune forever right? Intermediate engines usualy need to be re-tuned every once in a while, high end .12 race engines are usually re tuned every single day they are ran.
ON, CANADA
what could also be the problem(i ahd this on my car) is that the face of the air filter (where the sponge is) should face forward. i had mine with the cap peice facing forward and it wouldnt hit top end it would bog from richness because not enough air was getting it
FL
its wierd though cause when i would take the filter off it ran perfect ive been away for the weekend but tomorow il run it again and see how it does
FL
well i came back to a strange surprise, i took the car out to my backyard cause it was raining a little, it started on the first pull with the filter on, it stoped raining so i took it to the street when i get there it didnt work anymore and now its spraying fuel out the air filter[:'(] now my hand is full of fuel and my car doesnt want to start. Im thinking its the glow plug cause when i took it out to check if it was working it started smoking and didnt turn bright oreange until a few secs, do any of u gods of rc have an idea of whats going on i really wanted to run my car today
FL
yea but not moving just against a wall in backyard i know better than to run it outside without a filter i did it once on a baseball feild when i first got it im still asking myself why i did that lol
FL
hey nvm my car once again fixed itself its really weird somedays it will work then the next day same temp outside, havent touched the car, the same gas nothing different at all and it wont work.i think my car has a mind of its own.
