RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
servos not working right
Old 02-27-2007, 05:56 PM
wal_mart_security
Default servos not working right
my steering and throttle servos on my 2.5 4tec aren't moving as fast/not functioning properly and are making a weird buzzing noise...it hasnt been used for like 3 months. whats wrong with my servos?!
Old 02-27-2007, 06:06 PM
nitro08
Default RE: servos not working right
change your batteries
Old 02-27-2007, 06:17 PM
hpi apollo
hpi apollo's Avatar
servos sorta sound buzzy when they work, have you tried anything at all to fix them like replacing the batteries? try to fix first, then ask questions typically saves some time
Old 02-27-2007, 07:21 PM
wal_mart_security
i changed the batteries and the same thing happened
Old 02-27-2007, 07:50 PM
D-Nicest
Your servos, are most likely going bad, even though the car is new, did you ever run the car through water, also it coul be that there is binding, take the servos out and see if they are better when not acutally connected to your cars steering set up or throttle set up. You may just need to buy new servos.
Old 02-28-2007, 03:58 PM
wal_mart_security
actually i let it sit out in the sun and the throttle (which was facing the sun more) works nearly as good as it did before i stopped using it and the steering was a little better...could it be that it was just cold?
