Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC On Road Nitro Cars
Reload this Page >
GOING FOR 100MPH OR DIE TRYING.......More Pics Added!!!
RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Old 06-04-2008, 12:57 PM
  #201
ziggy12345
Default RE: GOING FOR 100MPH OR DIE TRYING.......
My 100 mph run was with a 200mm lola body with the rear wing cut off. I tried a touring shell and it took off.
If you need any help on high speed runs drop by my site www.fast-rc.co.uk and we will help you out all we can
Cheers
Old 06-04-2008, 02:19 PM
  #202
Saboteur10573
Most definitely a Lola is best for a high speed run to keep the car more stable. Otherwise for regular racing touring shell all the way. Haven't been on this site in years!
Old 06-04-2008, 05:29 PM
  #203
ferrarimk13
ferrarimk13's Avatar
hey saboteur, hows it been!?
ziggy, for your 3 motor car, howd you fuse the bodies? melted them, or was it custom made?
Old 06-04-2008, 07:18 PM
  #204
Saboteur10573
Ferrari - I've been good - just on the other forums mainly in the onroad section. I recently got back into 8th buggy and now race that class being the track is much closer and involves less money spent traveling. Floyd Bennett field lost their drivers stand thanks to the nasty park officials there. They will be working on getting a portable drivers stand though that will be a hassle to bring to the track all the time.
Old 06-05-2008, 02:47 AM
  #205
ziggy12345
You can get lexan glue. I overlapped them and then glued them. I also used some really fine glass matting ond painted on the lexan glue. It set like steel and worked great.
For the new design I am looking for a custom shell
Cheers
Old 06-05-2008, 09:51 AM
  #206
GYNAIKAS
GYNAIKAS's Avatar
I'd seen somewhere in the internet some guys that used a vacum cleaner to press preheated lexan on a custom form in order to get shape...
Old 06-05-2008, 10:40 AM
  #207
ziggy12345
Yeah I have seen that but you need to heat the lexan in the oven and the wife would kill me. Its exactly the same process as they use for commercial shells
Cheers
Old 06-05-2008, 02:27 PM
  #208
ferrarimk13
ORIGINAL: Saboteur10573
really? i havent been there in a few months, because im getting ready to start electric racing at 360. Thats weird, why would they do that?
Old 06-11-2008, 07:02 AM
  #209
Car-Tune
Default RE: GOING FOR 100MPH OR DIE TRYING.......More Pics Added!!!
I dont know if anyone has said this already...but that exhaust has to go and get replaced.
Old 06-11-2008, 08:10 AM
  #210
MiamizFinest
MiamizFinest's Avatar
ORIGINAL: C-Los
What are you talking about
Old 06-11-2008, 08:13 AM
  #211
Car-Tune
I was looking at the pics, the axhaust looks no good
Old 06-11-2008, 07:56 PM
  #212
Saboteur10573
ORIGINAL: ferrarimk13
Not sure. I think the other club who uses our spot when we aren't there want to claim the land. As of right now there are no races at Floyd - just practice with no stand.
Old 06-13-2008, 08:58 PM
  #213
ferrarimk13
wow, that sucks, you should check out the electric scene, really active at 360, and i should be out racing there for the winter, because i have a busy summer. My cars all ready to go, i just need a charger
Old 06-18-2008, 06:48 AM
  #214
ziggy12345
This car might get to 100
Old 06-18-2008, 10:48 AM
  #215
boosteda4tq
So what is the status in miami and drag racing....where are people going now to do so? Is it still worth it to build a Super RS4 for dragging or is there a better model out there right now. I am new to drag racing RC and want to get into it...i have a project car that im building now from scratch out of left over pieces but i dont expect much out of it other than just wanting to learn the basics and understanding what could make a car fast. Iknow they sell promod and etc kits but personally im the type of person who likes to get the impossible and make it possible it gives me more pleasure even if it cost more.
See you guys around.
Old 06-20-2008, 09:40 PM
  #216
need_to_drift
miami, u should keep trying and maybe put a .32 motor which is possible. im not new at rc but ive never looked at motors indepth. so u could try that. im a noob when it comes to engines but not rc in general.
Old 06-20-2008, 09:59 PM
  #217
NitroTherapist
Man ziggy your creativity never ceases to amaze me brother!
Old 06-21-2008, 05:43 AM
  #218
ziggy12345
Will it go as fast as it looks?
Old 06-21-2008, 05:53 AM
  #219
PAPE
PAPE's Avatar
ORIGINAL: ziggy12345
looking at your car. I think it would be verry coll to mount the intake pipe facing foward with a trumpet, youl get a boost in air going into your engine, but dont over do it or it will just cause drag
Old 06-21-2008, 08:56 AM
  #220
NitroTherapist
Can You give us some info on your car Ziggy?
Old 06-21-2008, 09:53 AM
  #221
ziggy12345
OK
Engine and drive train
Novarossi 35PLUS21 engine
RMV clutch
Mugen CLutch Bell
HPI 19/23 1st and 2nd pinion
Evolva 48/44 Spurs
Evolva one way with bearing reversed
HPC Mod 1 delrin reduction gears 28/36
HPC 1/1 bevel gear
Solid front axle to Kyosho 65x30mm 45 shore foams
26t 3mm pitch 6mm pulley driving 6mm heac=vy duty timing belt 884t
Rear wheel 28t3mm pitch 6mm wide pulley driven from front on one way bearing
Rear 65mmx30mm 45 shore foam
Rear steering
Radio gear
Futaba 351brushless servos
Futaba FASST 2.4 Ghz system
5 cell rx pack (might change to LiPo)
Kyosho Evolva SP brake pads
Kyosho Inferno GT Brake shoe
Fuel tank from Xray NT 18 (33cl give 45 seconds run time)
Home made bulk head from 4,5 and 6mm 7075 T6 Aluminium
Home made side braces from 2.5mm CF
Mercedes CLK 1/8th body shell with middle 120mm removed
The concept is no suspension and 3 wheel drive. The rear rotates at 90% of the front and sits on a one way bearing. As the car accelerates the fronts slip and the back takes over. As the car gets up to speed the fronts start to pull and the rear wheel idles on the one way
The rear fins help with high speed stability.
Testing tomorrow
Old 06-21-2008, 10:24 AM
  #222
MiamizFinest
Looks and sounds great, let us know how it goes make sure u take the filter off tho it would prolly kill about 10 MPH..........LOLOLOL j/k it looks great
Old 06-21-2008, 09:48 PM
  #223
NitroTherapist
Keep us posted Ziggy.
Old 06-22-2008, 02:21 AM
  #224
ziggy12345
Here is the flyer for the event if your interested
Old 06-23-2008, 07:11 PM
  #225
hitechglobalgroup
Not exactly around the corner for us....would love to go....See if you can use a HD camera to shoot the event....
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
