Broken connecting rod
Hi, Ran in my rs4 rtr 3 evo 15 today and during the 4th tank I went to start it and the roto start would not move. I turned the fly wheel by hand, heard a noise and then it just kept turning without moving the piston. Pulled it apart when I got home and found the connecting rod broken. The bush in the bottom hole was gone! I wasn't flogging it(did not even get into 2nd gear). I used the heat run in method. Any ideas what happened? Will buy a new rod and see what happens. Thanks.
RE: Broken connecting rod
It can happen sometimes, apollo is right, whether or not it happened WHILE you were priming, it is a result of too much fuel in the chamber when the engine performed a compression stroke. It happens sometimes, and was likely a minor defect with the conrod. Speak to HPI, they will probably replace it for you.
He said the bush went off the rod...If it's not pressed in there correctly it might come off which i suppose this is what happened!
talk to hpi they will take care of it, on those I would go pull start, you can tell if they are hydrolocked better because if they are you are not going to pull... the rotostart says ok and keeps going..
NJ
Yeah you probably didnt let the engine heat up enough or you kept it at a constant rpm. The sleeve has to expand during break-in for it to work properly. There is also less stress on the conrod while its hotter.
ORIGINAL: Ozboy
you proable banged it up your self BUT your lucky becuase alot of those T15 motor came defective at a point in time and who knows yours might be one of them.......call HPI they will replace it for you.............i actualyl had no idea about this defect untill i was talking to the owner of my LHS and he tolled me HPI called him one day asking for the RS4 EVOS back becuase of a bad batch............HPI was good about keeping it on the HUSH HUSH
