help with 18TZ..please
NY
hey guys, i finally felt like breaking in my engine, but the problem is that no matter how many times i try, and what i do, this thing will not start. Besides the fact that it always feels flooded (even though its not), it will not even get the sound like its about to start. i finally gave up after about 4 blisters on my pointer finger, so im asking if anyone knows what i should do. Oh, and i tried all combinations of fuel going into the carb, but it was no use.
RE: help with 18TZ..please
Glow plug dude it's the glow plug! After break-in most of the engine destroy the initial glow plug. Get a new one and be sure the voltage is enough to give the heat needed...the only way is to check it by removing it from the engine and watching if it glows well.
NY
i checked and it does, it couldnt burn out yet, i didnt even get it started once! thats the problem, its not starting, but the glow plug is good.
Does the engine have a pull start or are you using a starter box?
We would need to start ruling things out one by one starting by the easiest things first in hopes that its one of those things. GYNAIKAS was right with checking the plug. If you say its still glowing then move on to the igniter, is it fully charged? Sometimes the igniter will have just enough juice to make the plug glow in your hands but once its in the engine its not hot enough to start the car. If your igniter is charged then make sure you have no air leaks or cracks in your fuel line. I always use new lines with a new engine. If you are already using new lines then make sure you are using good fuel. Fuel can sometimes get stale. If you are using good fuel then its time to move on to the carb.
Did the engine come with any instructions? Do you have the carb factory settings? Here is a great article that can help if you dont have factory settings:
http://www.*********.org/cars_eng-tuning.htm
You might want to contact O.S. and see if they can give you the factory settings. If they do give them to you or you already have them then re set them and try again.
O.S. engines have a good reputation for being easy to start and tune so don't get frustrated, it could be something simple.
If all of this still doesn't work then you might want to re-seal the carb. You could have an air leak. Good luck and let us know if it fires up.
ORIGINAL: ferrarimk13
here is a little tip jsut becuase a glow plug lights up doesnt mean its good.......especialy during break in.....
if u wanna REALLY KNOW if a plug is good here is a trick very few people know put the plug on the ignitor once u see the cheery light up BLOW ON IT with ur mouth (not touching it ofcrouse) and see what happens............if it dims out ur plug is bad..........ud be surpirsed how many people dont know that and have problems.......check that out and see what happens
also try heating up the motor before it starts......most GOOD MOTORS will eat up plug left and right during break in.......my novarossi 528 ate 4 plugs during breaking in so i cost me 40 dollars in plugs just to get the dam thing broken in.....(it rusn of turbo plugs about 10 bucks a pop) so check that.....
also heat up the motor before u even try to start it up ud be surprised how often this helps AND loosen up the glow plug from the motor so there is less compertion when u go to turn it on.........let it blow fuel out of the glow plug hole like crazy till u see it temps up and then tighten it!!!
let us know how it goes!!!
Are you sure you have a TZ? I didnt know TZs came with pullstarts as to why you have blisters. If its indeed a TZ without a pullstart, check the rotation of the motor as well. I usually take the plug out (after making sure the plug is good) and then turn the motor over for a few seconds. Put the plug back in and it usually starts right up.
I forgot to mention that after brake in, you should remove the oil that has stucked into the pipe (remove and clean the pipe...you'll get surprized from what you're gonna see!!!)...after 1-2 days without firing up the engine, oil stiffens and maybe that's your problem.
NY
[link=http://osengines.com/engines/osmg2110.html]yup there a pullstart[/link] and everything is new on the car, i dont see how it can be the plug if it didnt even fire once yet, it didnt even reach the point where it seems like its going to start. The fuel is new, the line is new, and i did heat it up, which helped a lot. i have a question about the plug though, do turbo plugs need a spacer on it, or is that only for normal plugs. Also, im using the settings as it came out of the box, which should atleast start it, and then tune from there.
NY
how much fuel should i prime into the engine? i usually press the primer 20 times, or blow into the lines for 2-3 seconds
NY
i know if its flooded or not, but nothing spits out of the plug [link=http://youtube.com/watch?v=A2acLGnQGIE]this is why i primed it that much, i thought i needed to, lol[/link]
NY
good news guys! im breaking in the engine as i type, and im only into my second tank. It was a pain first agian, because it was idling too high, and if i lowered the idle just a tinnnny bit, it would stall, so the low end is set fine, but once im done, ill try the high, and im pretty sure ill have to lean the hsn a little bit, so it doesnt stall out, right?
i mean lean it out so that u can close the carb to ur desired idle speed. lees fuel means less air needed..am i wrong?
i broke it in. it was fully broken in after about 8 tanks. but i ended up fully tuning it up at about 20 tanks..lol..i used the heat cycling method plus just slowly increasing throttle every tank or so..so like the first tank, dont past 1/4 throttle. then the second tank dont past 1/2 throttle. and so on. n remember, slow squeezes of the trigger..
NY
i broke in my other 2 engines with no problems ( a .26 and .05) but the idle was a little too high, but i ran about 4 tanks at idle, and only bliped the throttle like twice to clear the carb up, i started doing little 1/4 throttle runs, and this thing was already doing a good 30 mph! it was blinding in acceleration. Eventually, i leaned it out a little, and the full throttle revs were amazing, it was so clear, and high pitched, and the wheels were breaking hell. I didnt run it on the ground full throttle (or 1/2 throttle) yet, because, if i did, id reach the fence in about 1/10th of a second, lol
NY
ill tell you this much, the cv-r is a lot more user friendly than the tz, and honestly, not everyone needs the extra power. Which car do u like more your kyosho or the hpi?
definitely my kyosho..in more ways than one..handling is superb plus the out of box adjustability is really amazing. and well im a novice driving and i beat two 3 evos, a cen ct5 and came in second to a ntc3 plus (but the driver was the best in the club there so go figure) lol..so i think stock (which is all i can give my opinion on) i rather my kyosho..i love it.
NY
oh, cool, yeah, the rs4 isnt all that great out of the box, but with some hopups, its super competitive, and can be tuned well, but i hope u have fun with the kyosho anyways!
NY
so the tide changes, it stopped, and it dried up, so i got in two tanks of 1/4 throttle driving, which is pretty fast , and i noticed that this thing handles great! is it usual that the car idles for 25 minutes? i finally times a tank, and thats the result.
