what postion should the throttle arm be
i am having a problem with my rc car recently my piston came loose so i took it out know i am trying to put it back in (it goes in) but the throtle arm is not in the wright postion and does not re v if you know what i mean can eny eny one help plz?
MN
RE: what postion should the throttle arm be
Have you tried searching for pictures to get an idea? All you have to do is put it on in such a way that the servo can open it all the way.
The adjustment is there for you so you can adjust it in every position. Power up your radio and try to make it work, IT"S SIMPLE!!!!
