gas pouring from the exhaust??
MD
my friend has a rs4 with a .15 on it its the old type i think an fe not sure, ive tried tunning it and all but i think its worn out if you let it idle for a couple seconds and take off, fuell dumps out the exhaust, i dont want to lean it any more if i do it will be running to hott... any thaughts??
RE: gas pouring from the exhaust??
You are WAY too rich! Even if it hit's 120 degrees it's normal even if it sounds hot to you. Don't worry. It's ok as far as blue smoke is comming out of the exhaust.
NY
your engine should be running around 200-250 degrees, and youll be fine. just turn the idle to the right about half a turn, like gyn and cypriot said.
