Which Fuel do you guys use?
NY
ORIGINAL: muti369
odonell 60%
odonell 60%
#34
I use to use Odonnell 20% but now I changing to Maxy's 20%. I start to see that odonnell does not have as much oil to lub the part as Maxy's. I did the test of running both..
#36
FL
The only reason I'm using TOP FUEL is because it comes in a metal can. I've run 3/4 of a gallon and no problems whatsoever. I think I'll experiment with o'donnels. It seems to be the most popular choice.
