RS4 3 HELP
My Feedback: (20)
IL
I just picked up a rs4 3 and need to get a rear hub carrier but don't know what model it is.I looked on tower and they have a bunch of different models.Do the parts on the 3 interchange between them.I tried posting a pic but it won't work,A link to what I need would be great.I need to get a parts list for this thing.It's shaft driven so I know it's a 3 but which one I don't know any help on the rear hub carrier would be great.I'm also in need of some good tires any info on a good set to look at would be great.Thanks
do you have a owners manual? go onto the hpi racing usa homepage. look for manuals and go to the exploded view which is almost the last page. and you will see a part number and search it.
IL
all RS4 3's are the same as far as all of the plastic part's go.
the only diffrences are the engine, trans, and electronic's.
your looking for the rear hub carrier? (plastic part that holds the wheel bearing's)
85037 L or R...i think they are the same part on either side.
you should go to venture hobbies in wheeling illinois...they have every HPI manual, and every HPI RS4 3 plastic part in stock, they also have most HPI RS4 3 upgrade part's in stock as well.
My Feedback: (20)
IL
ORIGINAL: one-syk
Thanks will check venture hobbies out for sure Thanks guys.
