Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC On Road Nitro Cars
 Difference between slick and traction tires??? >
RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Old 09-02-2008, 02:57 PM
Default Difference between slick and traction tires???
Ok, so I'm pretty new to the whole on road nitro car thing and I'm running a TA NTC3 with an OS .18TZ in it. I bought it from a guy and it had larger rims than stock and slick tires on it..I was having a hard time keeping traction with those tires, so I went back to the stock traction tires...Now it seems I'm having an even harder time keeping traction...I've been noticing alot of cars run slick tires and like I say, I'm kind of a newbie at the on road car thing (I have been running an HPI Savage for years). Can somebody explain to me if and why slick tires are better than traction style tires? These are the tires I'm running now:
http://www3.towerhobbies.com/cgi-bin...?&I=LXCZD2&P=7
I'm also wondering what glue you guys use for gluing the tires on the rims..I keep blasting the tires right off the rims..I'm using CA glue, but should I have scuffed up the rim first????
Old 09-02-2008, 04:45 PM
Default RE: Difference between slick and traction tires???
Those look really hard... If you want rubbers, get the HPI X-Pattern tires. They have great traction and last a good while (I'm running tarmac)
If you want even more grip, get some foams. Lower the shore rating is, the softer it is.
Softer it is, offers more traction, but less durability and vice versa.
I think the only things people run slicks on are slow electric on-roads.
Old 09-02-2008, 05:09 PM
You can tell they're hard by just looking at them? I like the looks of those HPI X Pattern tires, but I'm afraid I will probably end up with the same problem I have now.. It's impossible right now for me to take anything off the line because that OS is so freakin powerful!!! I want to be able to just shoot off the line and be gone!! So, I'll look into these foams that you are speaking of...any specific recommendations?
Old 09-02-2008, 06:53 PM
GYNAIKAS's Avatar
30mm wide rear foams and 26mm wide front foams.
Old 09-03-2008, 11:17 AM
HPI X pattern tires for the streets and use foam tires for the track.
I use X patters on my HPI RS4 with an OS 18 tz (on the streets) and I do get a pretty good launch out of that, foams on the streets will just spin.
Old 09-03-2008, 01:25 PM
Wow, you caught me just before I was going to buy some foams...Maybe I'll just buy both...then decide.
Old 09-03-2008, 02:53 PM
What gives better traction in a car park
Radials or slicks?
Old 09-03-2008, 09:47 PM
Slicks, foams are better on the track though.
Old 09-04-2008, 09:33 AM
GYNAIKAS's Avatar
The radials you mean in fact are not "radials"...they are semi-slicks to be honest...radials are used only in real cars...so semislicks are better on wet surfaces and slicks for dry ones. Foams are for maximum grip at dry surfaces.
Old 09-04-2008, 09:52 AM
rc rock's Avatar
slicks it is then right Spetz??? no wet conditions here huh??
Old 09-04-2008, 09:53 AM
No slick tire on RC car or real car is good in the wet road
Old 09-04-2008, 10:47 AM
ORIGINAL: rc rock
Hopefully it'll rain once or twice this winter
But I guess we can live without driving our RC cars one day, can't we??
Old 09-04-2008, 05:38 PM
GYNAIKAS's Avatar
ORIGINAL: C-Los
You mean that slicks are good when on wet surface??? Or you mean that there's no good slick on wet surface???
Old 09-04-2008, 10:32 PM
Slicks are not good in the rain. The water needs to be thrown from out inder the tires or in will hyrdoplane <what ever its called when tires float above water. If you ever see Formula 1 races..they change out the slick tires to treaded tires. No mater how good a slick is, its useless in the rain.
Old 09-05-2008, 06:39 AM
GYNAIKAS's Avatar
Yes I know...I only want to know what exactly does he mean in order to reply properly...
Old 09-05-2008, 07:20 AM
I had these Bridgestone Potenza S-02 tyres on my car (1:1)
Boy were they good in the wet! And the dry too of course
Old 09-05-2008, 07:23 AM
Bridgestone Potenza tires are pretty damn expencive too. I had them too, but the bad thing is that they wear out too fast, yet give you a very good traction.
Old 09-05-2008, 08:30 AM
My Feedback: (8)
proptop's Avatar
If you're using rubber tires, with that much power, you need BELTED rubber tires.
The cheaper, non-belted tires will just grow larger and larger as they spin faster, and pull away from the rims. The belted type will grow much less and will tend to stay on the rims much better.
I use slicks almost exclusively...unless the surface is really dusty.
Foams will work, but you need relatively soft ones to work in a parking lot (for instance ) and they will wear quickly...but at least they'll stay on the rims.
Old 09-05-2008, 08:43 AM
ok how do the x patern hpi rubber tires redpond in a wet condition. i must be prepared for a race in the wet....
Old 09-05-2008, 09:10 AM
It never rains here Cypriot boy
Old 09-05-2008, 09:55 AM
GYNAIKAS's Avatar
The best tire for the wet so far is the kyosho semislick set...
Old 09-05-2008, 10:05 AM
"G" how is any slick tire good on rain? I dont think any RC car can handle good at any wet surface. I will be surpriced if they do handle good.
Old 09-05-2008, 01:38 PM
GYNAIKAS's Avatar
ORIGINAL: C-Los
Slicks suck. Kyosho's semi-slick rule. Here it is. I have used this tire on my ex 1:10 racer (RRR) on a wet surface during race with magnificent results! Pay attention to the way it curves...all the other conventional rubbers are flat and they don't push water away of the contact point.
ID:	1026744   Click image for larger version
Old 09-05-2008, 03:14 PM
So "G" what is the model # for those tires?
Old 09-05-2008, 04:19 PM
wow could you send me some of those semi slicks!! i love them!!
and also spetz it better rain or else we will be having problem with water......
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
