Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC On Road Nitro Cars
 hpi rs4 evo engine help! and driving setup >
RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
Old 09-04-2008, 10:25 AM
Default hpi rs4 evo engine help! and driving setup
hi,
i have a hpi rs4 evo and i went for a run with my mates. after a while it stalled. the engine started but each time i touch the controller trigger it stalls, when i start it it starts from slow to high rpm all by its self
and if i engage the throttle it stops.
i removed the engine and looked at the clutch etc but nothing wrong apart from dirt on the clutch. i brought a racing clutch. it also takes ages to start.
help help help
my question:
what engine is faster durable and better: os .18 cv rx, 18ss outlaw, hpi t3.0 (please be onest)
i just brought
highest pinion gears and clutch bell (19t and 23t) i get ratio of 2.2 for 2nd gear and about 2.6-8 in 1st (is that ok?)
HPI Nitro Racing Clutch 87191 for Nitro RS4 3 18SS R40
spur gear(39t)
fuel line|
aifilter oil
pro racing chasis
Heavy Duty Diff Shafts
Front L+R Hub Assemblies Inc Bearings & Hex Hub
Servo Arm Kit
Tub Of High Performance Joint Grease
Exhaust Gasket
Hot Glow Plug
2 x Long Dogbones
2 x Short Dogbones
Diff Cups
hpi body clips
antenna tube
I WANA GET A ENGINE BUT I DONT NO WHICH ONE:
18SS (40000 RPM STATED HPIRACING.COM)
T3.0(32000)
0S .18 CV-RX
PLEASE HELP
here is a pic of my car is my suspension ok?green front black rear
ID:	1025954   Click image for larger version
Old 09-04-2008, 01:09 PM
MiamizFinest's Avatar
Default RE: hpi rs4 evo engine help! and driving setup
Bein honest neither one of those motors r a good choice, the best choice is the OS 18TZ but ull need the header
Old 09-04-2008, 02:02 PM
yeah thanks but i dont have the money + i need to buy another tuned pipe
Old 09-04-2008, 02:46 PM
no u can keep ur same pipe and jsut buy the 12 dollar header so u can use it wit hthe pipe u have now............ if u dont have the extra to spend on the TZ the OS 18 TVRX will be the best choice over those HPI motors...........ive had all 4 motors and trust me the HPI small blocks suck
Old 09-04-2008, 05:36 PM
GYNAIKAS's Avatar
Well the 18ss has proven itself faster than the CV-RX several times...especially after the modification...! Also it revs significantly more... But it's discontinued so I recomend the LRP z18s.
Old 09-04-2008, 10:24 PM
ORIGINAL: GYNAIKAS
i had the 18SS motor when they first came out about 3-4 year ago, i had the version with the purple head that u could only get if i bought it NIB not from a RTR kit, yes ur right it did rev more than the 18CVRX but with the OS 18 i was able to gear much MUCH higher so i made up for lack of revs with gearing and it flew, i had both motors stock not modded
BUT I HATED THE STUPID SMALL HEX HEAD IDLE SCREW ON THW 18SS MOTOR WHAT A PAIN IN MY ASS IT WAS!!!!!
Old 09-05-2008, 06:41 AM
GYNAIKAS's Avatar
LOL But still it's the greatest engine HPI has ever mopunted on a stock chasis!
Old 09-05-2008, 04:54 PM
ORIGINAL: GYNAIKAS
thats tru rember tho old 15FE??? man those things SUCKED
Old 09-05-2008, 05:17 PM
cv-rx it is thanks guys
and is green springs on front a rear blak ok?
my ride height at the black exceeds 1 cm!
(no engine in place)
rd logics or ths tuned pipe
Old 09-05-2008, 05:37 PM
GYNAIKAS's Avatar
First mount the engine and adjust te height with the spacers. Rear should be 1mm higher than front.
Old 09-05-2008, 05:42 PM
i have no spacers tho..i have tie rod links tho
Old 09-05-2008, 05:58 PM
RD logics turbo OUTLAW pipe is a few good choice,
ive tuned alot of cars with the THS pipes and even tho they make some power over the RD logics i wouldnt cosider them TUNED since ive always felt the dont have the right backpresure and lean the motors out, u might think its performing good but ur engine is screaming HELP ME HELP ME
Old 09-05-2008, 06:09 PM
GYNAIKAS's Avatar
ORIGINAL: l0lzpl0x
You should get spacers. They cost almost nothing.
Old 09-05-2008, 10:20 PM
Yeah, get some or make your own. They just clip right on the shock above the spring to compress spring lightly to set ride height. In a pinch, use zip ties. Just use the medium large ones that are about 4mm wide, zip it on around shock above spring and cutoff extra. Plus, you can get them in almost any color to match your color theme. Springs should be ok, run it and see how it goes!
Old 09-06-2008, 05:53 AM
thanks and nice tip cbm,
miami - i dont think i can get that pipe i was thinking of the normal one,
i also found skyline 1 pc pipe it has dual chamber
btw i have 2 shock spacers on the front ride height is about9 mm- 1cm
rear is over 1.6cm(no engine / tank
Old 09-06-2008, 07:03 AM
GYNAIKAS's Avatar
Zip ties are not good for that. Get spacers cause you have to be more precice with your suspenssion setup than you think...
Old 09-06-2008, 08:48 AM
if i do where do i put them on front or rear
thanks
Old 09-06-2008, 09:25 AM
GYNAIKAS's Avatar
Dont do it...get the spacers. The chasis height from theground for track setting is 5mm front and 6mm rear.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
