Kyosho V-One RRR Evo 2 help.
OK, so I've bought a brand new Kyosho V-One RRR on fleaBay for a little over $400 Australian bucks, a Picco .12 JLR Red Dot with Race Mod from ABMods, getting the 2651 pipe soon for about $100 from RC Mart (or whatever) a Lola Body that I'll paint black with red stripes in the middle (or maybe something else, give me some input on a two colour paint-job) I have a 2.4Ghz Tactic TTX240 radio with Futaba S3010 servos all round and now all I need is a receiver battery!! I've tried searching around for what kind of flat pack would suit it but I don't know what size I should get (what dimensions for the battery) So this is where you can all put your ideas and opinions on what would be a good pack for it!
Thanks in advance, D.DJ.
RE: Kyosho V-One RRR Evo 2 help.
And also, if anybody knows, which plug would be good for a pretty short/tight course (straights are about 15-20 metres long) and one for some speed runs. Ill be using 20% fuel with 15% oils in it. Thanks again.
VA
well any flat pack should work (5 cells) im useing a reedy ... http://order.aeteam.net/product_detail.asp?Itemcode=613 life is pretty good it last me practice and 3 qualifying (depending on how much i practice) i always charge it before my main.
for the plug you'll usually use a 6 or a 7 for .12 engines. i run my RB R3 with a 7 plug
have fun, i like my rrr evo2 alot
well any flat pack should work (5 cells) im useing a reedy ...http://order.aeteam.net/product_detail.asp?Itemcode=613life is pretty good it last me practice and 3 qualifying (depending on how much i practice) i always charge it before my main.
Thanks for the input though!
VA
I use novarrosi plugs They have two versions use the shorter kind, I think it's c7. Or see what your manual says my engine is Nova based so I know I can't go wrong with novarrosi plugs
I think a p5 would be too hot. See what plug comes with the engine and buy the same ones
ORIGINAL: olkleaf
OK RCU people, solutions have been found!! Got the battery pack and the plugs are not a problem any more unless they stop selling them, which in my case will suck!! Feel free to give me some good design tips on a 2 colour paint-job for my 200mm Lola body using RED and BLACK, that's what Ive got.
