RC On Road Nitro Cars Discuss all aspects of on-road nitro rc cars here
HPI RS4 Upgrades...
Old 02-08-2010, 09:31 AM
Vanka472
Default HPI RS4 Upgrades...
Hey guys, im looking to get this thing totally upgraded and I have no clue where to look and what to get. I would like CNC and graphite, carbon fiber really anything I can get. Thanks alot for you help. You guys have any pics please feel free to post them!
Cheers,Vanka
Old 02-09-2010, 08:25 PM
skyraider71
skyraider71's Avatar
Default RE: HPI RS4 Upgrades...
Do you mean the old belt-drive Nitro RS4-2?
Old 02-10-2010, 10:19 AM
ROUDYRS4
EBAY
Old 02-10-2010, 11:25 AM
Vanka472
no not the belt version and Ebay will work...but I need to know what to find. Like what parts. Thanks for the response.
Cheers,Vanka
Old 02-10-2010, 09:41 PM
skyraider71
One of the things that you want to get is the light-weight aluminum fly wheel. A carbon top plate
and shock towers are available. Get these from HPI.
Old 02-11-2010, 06:35 PM
magnus213
magnus213's Avatar
I'd recommend the carbon fiber upper deck and shock towers. I would advise against aluminum parts because despite looking nice, they add weight and don't really benefit performance much. In a crash they also won't fare very well, ending up bent where plastic would have either flexed and rebounded or broken and called for an inexpensive replacement.
As for drivetrain parts, I'd recommend a racing clutch and fiber brake to start.
Old 02-16-2010, 01:43 AM
Vanka472
Thanks guys! I will most def look into getting those parts! I have heard some negative things about the aluminum parts and im think carbon and graphite are much better improvements. As for shock towers would you be referring to these?
http://www3.towerhobbies.com/cgi-bin...?&I=LXGNU4&P=7
and where can I order these parts? I know HPI has them but where else would you suggest? Also I would like to upgrade serovs if possiable...
Thanks again!
Cheers,Vanka
Old 02-16-2010, 02:43 AM
Vanka472
Also I get $20 of my order of $50 at tower right now...so something that adds up to that would be sweet! Thanks again
Cheers,Vanka
Old 02-16-2010, 06:54 PM
magnus213
magnus213's Avatar
What model HPI do you have? This is in the nitro on-road section and the Pro 4 is an electric sedan, so your link won't work out.
Old 02-16-2010, 08:32 PM
Vanka472
Its the rs4 3 on road version. I found those parts though! what about servos? Thanks
Cheers,Vanka
Old 02-17-2010, 08:47 AM
93dabeast
Flywheel:  http://www3.towerhobbies.com/cgi-bin...?&I=LXM759&P=Z
Clutch:  http://www3.towerhobbies.com/cgi-bin...?&I=LXLST3&P=7
Engine: http://www3.towerhobbies.com/cgi-bin...&I=LXGGP7&P=SM
Exhaust: http://www3.towerhobbies.com/cgi-bin...&I=LXCPX4&P=SM
Servos: http://www3.towerhobbies.com/cgi-bin...UZ87&P=0
and : http://www3.towerhobbies.com/cgi-bin...?&I=LXUZ89&P=0
done
Old 02-17-2010, 09:06 AM
93dabeast
oh and the mounts for that motor as well as the fiber brake
Old 02-17-2010, 02:12 PM
Vanka472
Thanks a ton man!! Thats awesome! Now here is the thing. I have a new .16 engine in there with a tiger drive. How still need the flywheel? Also What would you say is the most important part that Out of those that I should get. Maybe put in order not the links just the items. Because if possible I would like to get this thing upgraded the right way. Thanks again your great!
Cheers,Vanka
Old 02-23-2010, 08:47 PM
skyraider71
The idea behind the machined aluminum fly wheel is reducing rotating weight.
The first things I would change are the clutch, and brake disk. Then consider
a good quality radio set.
The racing clutch will hold up much better than the stock one. The fiber disk
will increace stopping power greatly. Even a mid-range radio will give better
control and reliability than the stock unit. Reliabilty is the key in a car that can
go 50+ mph.
Old 02-24-2010, 12:22 AM
str8.krooked
str8.krooked's Avatar
figured you might like this...it's drifting...
WWW.YOUTUBE.COM/COLORADODRIFTRC
Old 02-24-2010, 12:47 AM
str8.krooked
sorry...double post.
Old 02-25-2010, 02:02 PM
skyraider71
In-car drift-cam, nice!
Old 02-25-2010, 08:58 PM
Killertiger
Hey, I don't mean to hijack this thread but I was thinking about upgrading my 1 speed transmission to 2 speed and needed some assistance.
I can't seem to figure out what I need to buy, do I need to purchase something like this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXBTB6
or is something like this enough?:
http://cgi.ebay.com/Nitro-RS4-3-Evo-...item5ad77c7751
or is there any other recommendations? Also what else could I upgrade without spending too much for better performance.
Old 03-18-2010, 05:37 PM
Lelolai
Hey guys, i have been wanting to get an HPI RS4 for the longest time, and now i finally got one. The guy that i bought it from has an O.S. 15CV-X on it. I use my RC to race on tracks at times, but mostly use them to bash up and down the street with my neighbor. Is this engeine good for this kit, or is an .18 CV-R better?
Thank for your help!
Old 03-18-2010, 05:55 PM
GYNAIKAS
GYNAIKAS's Avatar
@Vanka472-> Check my profile pics. It's tuned with PROPER rather than expensive parts...riped at open class shaft-driven car races...Check whick part you like and pm me for extra info...
@Lelolai -> I've modified the 18ss engine and YES it revs more than the tz and it is almost as powerful as an OS .18tz. Weighting less and reving higher makes it better for track use than the tz. So modify your current engine (exhaust, filters, proper glowplug, perfect adjustment and if you have the means inner modification -> ports/sleeve etc.)
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
