Inferno GT
My Feedback: (27)
Inferno GT
I just picked up an Kyosho Inferno GT last night and it has the stock gx.28 engine on it with those funky engine mounts that are molded into the crankcase. Does anybody know where I can get a set of engine mounts that will fit with this car. I am going to be replacing the engine if I can find the mounts for it.
Also anybody know a good source for parts?
RE: Inferno GT
Anywhere that sells 1/8 scale engine mounts will fit into it I believe. eBay is a good place, but you might have a shop closer to you that can have one. Search online and you will see....
What do you mean by the engine mounts are moulded into the crankcase? Do the bolts that hold the engine onto the chassis go straight into the engine (essentially having no engine mounts at all)? Or the engine mounts are moulded to fit the shape of the engine crankcase?
RE: Inferno GT
Ahh, I see. Then like I said, any 1/8 size mounts should fit into it. Just make sure that there are holes in the right spot for the mounts to fit, otherwise you will have to drill your own holes for the mounts. Shouldn't be too hard, it's only a minor mod so it shouldn't damage the chassis strength. Just don't mess it up
My Feedback: (27)
RE: Inferno GT
ORIGINAL: D.DJ
RE: Inferno GT
well if the holes you are talking about are 2 holes on each end, 4 in total, then it should be fine. But if the holes are for the original engine, then there aren't any engine mounts that are shaped like that, not with 3 holes anyway.
RE: Inferno GT
Guys
How many of you out there are still running the Inferno GT. It's been discountinued for a while now and been replaced by the GT2. I got my GT out again today in a long time and discovered that the clutch shoes spring had snapped during the last run.
Atleast the stock GXR28 engine started without any problems that hadn't been run in a while. Hopefully get my hands on some spares tomorrow and have her fit for the following week.
A friend has just bought a GT2 so let the races begin!
Cheers
Etops
Cheers
Etops
RE: Inferno GT
you need this http://www.amainhobbies.com/product_...Mount-MP75-777
or if you want orginal kyosho:http://www.amainhobbies.com/product_...d-Engine-Mount
