fuel tubing from gas to pipe
what is the fuel tubing for goin from the gas tank to the exust pipe
RE: fuel tubing from gas to pipe
your a super member and you still dont know what that is... naw but yea anyways thats the tube i think that sends pressure pluses to the gas and thats what keeps the fuel comin to the carb. its from the exhaust to the tank
im in to electric
oh mybad
Just like raceme said, the fuel tubing allows pressure from inside the exhaust pipe to enter into the fuel tank.
Then the fuel can be pushed into the carb easier. If it didn't pressurize the fuel tank, you wouldn't get as good as performance because you would only be using gravity to feed the fuel into the carb. |
it makes that nasty stalling noise like the carb isnt getting fuel it sounds nasty
i drove wit the pressure line off before. it still runs but you cant stop for to long right when you stop the fuel stops and the engine cant idle. so you have to keep the throttle open.
