RCU Forums
-   RC On Road Nitro Cars (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/)
-   -   Low speed needle coming loose? help (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/1300575-low-speed-needle-coming-loose-help.html)
louielc 11-23-2003 08:47 PM
Has anyone ever heard of the LSN coming loose as the car idles. I adjust mine and then as it idles for like 5 seconds it tightens up, gets too lean and the car dies,--the only way I can keep the car running is to take the low speed needle all the way out.--someone told me Teflon tape or red thread lock-but has anyone actually had this problem and fixed it? help
dbow 11-23-2003 09:17 PM
RE: Low speed needle coming loose? help
If this is a new engine I would send it back to the manufacturer.
Dbow
louielc 11-23-2003 09:48 PM
I cant-I dont know where the reciept is anymore-cause I bought it three months ago and am just now trying to use it
scale only 4 me 11-24-2003 07:04 PM
That's odd, usually things want to vibrate out, not in?
I would take the needle out and make sure it has the O-ring on, that might be a 5 cents/trip to the hardware store fix?
Good luck
dg2b 11-25-2003 01:08 PM
Some carbs has a spring clip to lock the needle in place through a groove(sp). I've seen these on OS carbs and others. What kind of engine do you have?
dbow 11-25-2003 01:22 PM
In most cases send the engine in to the manufacturer.
I would call them first and tell them the problem.
Dbow
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
