RCU Forums
-   RC On Road Nitro Cars (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/)
-   -   engine problem (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/2511034-engine-problem.html)
Dvskerry 01-06-2005 11:41 PM
engine problem
today when I started my car i reved it and when I let off it stayed the same but the carb was still on idle. the servos were fine but for some reason the car just wont slow back down to idle
kwong2001 01-07-2005 12:03 AM
RE: engine problem
Hmmm, well my first suspicions would be an air leak. But before you go sealing up the engine, did you check to make ABSOLUTELY sure the carb was going back down to idle? It could be sticking, which means you'll need to clean it. Or your throttle linkage might not be setup properly.
What happens when you let it rev and you put it on the ground so it can't move?
Dvskerry 01-07-2005 01:40 AM
RE: engine problem
Thanx for the tips man ill check it out
