Something leaking off of my flywheel NTC3plus
Today after cleaning my car i noticed a small ammount of some kind of goldish liquid under where my car was sitting :eek:. After closer review i can see that it was dripping off of the flywheel. I tried to get a closer look but i cant find where the leak is comming from. Any help would be much appreciated
-Tal3nt |
RE: Something leaking off of my flywheel NTC3plus
You might try pulling the whole clutch assembly (including the flywheel) off, and checking the bearing on the engine block to see if that's the source. Could also be coming from the carb. If you can't find the problem, try sealing up the engine real good and see if that takes care of it. I know i'm stating the obvious, but it's it's probably just a leak somewhere. Could even be coming from your fuel tubing.
But i gotta tell you, i never seen a goldish liquid before. You sure it wasn't on the carpet before? |
it was actually sitting on a shoe box so i could see the liquid clearly, and this is my first RC car, im pretty good at figuring stuff out but do you have any tips oh how to seal up the engine?
Well i've never sealed an engien before, but i think they use some sort of silicone type stuff to do it? I'm sure someone else can tell you exactly what to use.
