What is the lubricant use for?
what is the lubricant use for? i read on forums say they are use to treat ur engine good. do i use it for my pistons and bearings inside the engine? what kind of name brand lubricant are good? sorry im new and i need to alot about rc.
RE: What is the lubricant use for?
WD 40 you can use it on everything
O REALY,THANX
wd 40 isn't good for engine that use siliocon o-rings because it eats it away, a bottle of After run oil will lst a long time
wd 40 isn't good for engine that use siliocon o-rings because it eats it away, a bottle of After run oil will last a long time in fact I've been to places where nobody uses after run oil at all unless you are storing your car for a long time just make sure you run your engine dry and clean out the fuel tank wd40 is fine |
