bad brakes
oki got a rs4 evo and i have about 3/4 of a gallon through it and the 1st couple of tanks the breaks are reel good but now they suck i mean the break doesnt really wear does it?
what the heck is wrong |
RE: bad brakes
try to tighten the black knob on the brak linkage.. thats all i can think of..
RE: bad brakes
yep do what rshooch says :)
RE: bad brakes
What vcar do you run? My brakes get crappy after a while because the fuel tankis close to the brake, it gets coated in fuel when I spill. Only thing I can do is clean it down.
RE: bad brakes
If the brake is binding in any way then it will wear quickly and become totally useless. Best to remove the disc and check it and the brake pads for signs of wear, melting, fuel etc.
RE: bad brakes
yea tighting the black screw thing on the linkage worked thanks guys
