RCU Forums
-   RC On Road Nitro Cars (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/)
-   -   rs4 evo+ diff spring (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/6759430-rs4-evo-diff-spring.html)
da mad maori 12-15-2007 04:13 AM
ive heard some people leave/take this spring out... whats the effect of this?
Cheers
GYNAIKAS 12-15-2007 08:12 AM
RE: rs4 evo+ diff spring
It stiffens the front differential for better cornering. If you use 10k silicon oil at the rear and 10k silicon oil at the front + the spring then your actual front diff stifness will be 40-50k.
ferrarimk13 12-15-2007 11:51 AM
what spring is it? i never know what it is.
GYNAIKAS 12-15-2007 10:10 PM
1 Attachment(s)
That's the spring budy :)
Josh222 12-22-2007 04:43 PM
You definably want to leave the spring in there, I would recommend picking up this spring set HPI makes just for the differentials. It comes with springs of different stiffnesses so you can try to see what one you like best. You could use Silicone oil but because the RS4 3 does not use sealed gear differentials the oil will leak out over time and make a real mess, not fun to clean up.
http://www3.towerhobbies.com/cgi-bin...?&I=LXZT47&P=7
ferrarimk13 12-22-2007 09:56 PM
oh, so it pushes out the two little gears so it pushes it harder?
Josh222 12-23-2007 01:14 AM
Yes, it acts like oil. I run the Gold spring in the front and the black in the rear. My rs4 3 is setup for high traction surfaces and I am not sure how it would handle in lets say a parking lot.
ferrarimk13 12-23-2007 12:50 PM
oh, is the spring in the original RS4 3 model too?
Josh222 01-01-2008 02:37 AM
yes
