RCU Forums
-   RC On Road Nitro Cars (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/)
-   -   Centre Diff (https://www.rcuniverse.com/forum/rc-road-nitro-cars-242/8062618-centre-diff.html)
Spetz 10-19-2008 04:32 AM
Centre Diff
Hey guys,
I have a friends RC car which I am trying to setup/fix.
It has a centre differential and from driving it, it handles much like a FWD car. It has a rear swaybar so it kind of understeers on throttle (the front wheels start spinning) and oversteers off throttle. It's fairly easy to drive though this way however it lacks acceleration because it just spins up the front wheels
I have a locked centre diff for it as well and wondering which would be best to use? Open or locked?
I notice with my car which has no centre diff, power oversteer happens relatively often where as the car with the centre diff has no chance of doing that
Suggestions??
rc rock 10-19-2008 09:09 AM
RE: Centre Diff
what car is this???
Spetz 10-19-2008 10:04 AM
RE: Centre Diff
My friends car is a GV of some sort
It's got 280mm wheelbase so it's a super10 size car (like mine as well)
Spetz 10-19-2008 10:07 AM
RE: Centre Diff
http://i26.photobucket.com/albums/c1...3/DSC02527.jpg
http://i26.photobucket.com/albums/c1...3/DSC02526.jpg
http://i26.photobucket.com/albums/c1...3/DSC02525.jpg
http://i26.photobucket.com/albums/c1...3/DSC02530.jpg
http://i26.photobucket.com/albums/c1...3/DSC02528.jpg
GYNAIKAS 10-19-2008 06:03 PM
RE: Centre Diff
Try softer springs at the rear. Oversteer happens cause it's not 2 speed so you have engine braking when you're off throtle.
Spetz 10-20-2008 02:32 AM
RE: Centre Diff
The oversteer/understeer isn't an issue, i'll set it up later
I'm just wondering what is better overall for a asphalt track
Open centre diff or no centre diff?
GYNAIKAS 10-20-2008 10:11 AM
RE: Centre Diff
Definately a fully locked differential or a 2 speed-no differential gearbox...
Spetz 10-20-2008 10:24 AM
RE: Centre Diff
To be honest I liked how my single speed was...
The 2 speed is sort of annoying because when rolling and going onto throttle it "hits" too hard when the one way and the shaft reach the same speed
Plus I like the noise the engine makes when you let go of the gas but its still in high revs from the roll
GYNAIKAS 10-20-2008 01:12 PM
RE: Centre Diff
Well it's ok to me but engine braking will be always causing rear end unstability while cornering. If you don't lock it then during a corner front wheels steer and tend to decelerate while weight transfers happens to the front end wich tends to lift the rear end...that reduces rear traction while center differential transfers torque to the rear wheels and you loose rear end!!! Once you lock it this fixes but you still have the engine braking issue.
Spetz 10-20-2008 01:57 PM
RE: Centre Diff
I will lock it and see how it goes
In reality it's not serious racing, just me and a friend "bashing" on a track really
I've never driven on a track before and I'm looking forward to it :)
Spetz 10-20-2008 01:58 PM
RE: Centre Diff
Edit:
Wrong Thread :)
WalawalaStore 10-22-2008 03:41 PM
RE: Centre Diff
if you are doing on road, the center diff can be locked. The purpose of the center diff is to split power between front and rear axles. If it is locked, the rear axle gest 50% of power everytime you nail on the throttle, if the center diff is unlocked (also depends on how hard diff oil you use), some of the power will be transfer to the front (minus from the rear) axles during acceleration, making it more like a FWD car, easier to drive.
I think you will need harder springs for on road.
Spetz 10-23-2008 05:49 AM
RE: Centre Diff
Yup I already put the locker into it :)
