Hard decisions! Need your help
Hello all,
Ok I am currently into RC Tanks and have a YouTube channel which I enjoy producing videos (RC Tanks 24/7)
https://www.youtube.com/channel/UC1J...view_as=public
But now I am wanting to get into the scale truck side of the hobby. I have Tamiya Tundra with a Rooster Esc and a 55t motor which is cool but I purchased it second hand.
So I now want to buy another quality Scale Truck Kit as I enjoy building them as much as I do driving. Question is which one do you guys recommend?
I am looking at the Triai Finder 2 kit form then get my own electronics but which esc, servos etc
Appreciate your opinions guys
Steve
Steve
Any of the Hi-Tec servos would fit your needs, as far as ESC's, I only have used the Axial AE-2, and have had no problems. I know there are better ESC's out there, and maybe some other members can help you with those. A 55t motor will give you a scale crawl, but if you want something with a little more oomph when you need it, try a 35t. I run an Integy 35t on both my 1/6 Jeep, and my SCX10 Chevy Panel.
That will depend on how much you are willing to spend.
like mike said the Hi-tec servos are good ones to use. i use them in 3 of my 4 RC's. there are better ones but cost more.
Any ESC with forward, reverse and a drag brake will work fine. i would recommend the tekin line of ESC's only because that's what i'm going to go for. but rc4wd, axial and vaterra have great crawler ESC's. they should they are all in the top of the RC crawler/trail truck scene. as for a motor i would go for a 35T. good torque and power. i'm using a tekin 35T in my sxc10 and a 60T in my venom creeper and the 35 will run circles around the 60 but the torque in the 60 is almost twice as much. so for the TF2 grab a 35T. remember the higher the turn number the slower you will go.
I've never owned one, so my opinions are limited. The TF2 uses leaf springs as opposed to Axial's coil-over shocks, which will limit articulation, but give you a more scale running vehicle. Axial parts are readily available from most hobby shops that carry Axial products, whereas not all hobby shops stock or can order from RC4WD. I personally have not had issues ordering directly from RC4WD, but if you look through other forums, there are numerous complaints. RC4WD does not have a contact phone #, all their customer service is done through e-mails...good luck!
