RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
what the best servo for scx10
Old 08-25-2015, 09:41 PM
dirtytanker
Default what the best servo for scx10
I can get a Hitec HS-645MG for my truck.
Old 08-26-2015, 11:58 AM
RustedRC
RustedRC's Avatar
That will depend on how you will run it. if it's stock and your light trailing and crawling then a hi-tec 645 mg works good but if you going in water you need to water proof it.
after adding some weight you might need to go for a better one like maybe a SAVSW0241MG. i'm going to get one soon. all my 645's are stripped but i'm not easy on them.
Old 08-26-2015, 01:48 PM
dirtytanker
yea its stock apart from my custom made lower links.
Old 08-26-2015, 04:52 PM
RustedRC
RustedRC's Avatar
Then the 645 should work fine and even better after you waterproof it.
Old 08-26-2015, 06:10 PM
Mike Flea
Mike Flea's Avatar
I waterproofed my 645mg by opening it up and putting a ring of die-electric grease around the top where the servo horn attaches then put the top back on so it sandwiches the grease, then used a conformal coating like liquid electrical tape around all the seams, and the body screws, works great, did the same to my new Savox SA-1231S. The Hi-Tec worked great for an SCX-10, but for my 1/6 Jeep at 14lbs I needed to upgrade to the Savox.
Old 08-27-2015, 02:51 AM
dirtytanker
I got a Hextroink HX12R
Old 08-27-2015, 06:28 AM
RustedRC
RustedRC's Avatar
awesome dirtytanker. now you can get back to them trails. i haven't heard of that servo but hope it does good for you.
look up how to waterproof a servo on youtube. there is a few good vids on there about it. i followed DJ medic's guide but squirrel and a few other guys do a good vid on it to.
Old 08-27-2015, 12:52 PM
dirtytanker
It hopefully go ok at a CRCC4x4 meeting I'm going to its at 4WD park and what are the SAvox servos like.
Old 08-27-2015, 01:03 PM
RustedRC
RustedRC's Avatar
Don't have any yet but there next on my list. mike flea or someone will help you out better than i can. but IMO there great. i wish i had like 5 right now.
Old 08-27-2015, 02:12 PM
dirtytanker
For waterproofing I use CRC 808 spray on silicone
Old 08-27-2015, 03:23 PM
RustedRC
RustedRC's Avatar
that works too. i like to use plastidip and marine grease but just as long as it gets the job done that's what you need.
take some pic's at your meeting and post'em up.
Old 08-27-2015, 04:46 PM
dirtytanker
will do
Old 08-27-2015, 04:54 PM
dirtytanker
does the Tactic TSX45 come on all scx10 or only some. what i'm asking is a stand servo fot axial.
Old 08-27-2015, 06:25 PM
Mike Flea
Mike Flea's Avatar
The standard servo on my Ridgecrest was the AS-3, and that's what I put on my home built scx-10.
I just put the Savox on the jeep, as part of the rebuild, because the Hi-tec wasn't cutting it on the rocks with the heavier weight. The SA1231-S has 444oz of torque compared to 164oz on the 645mg. Don't get me wrong, the Hi-tec works great for a lexan bodied scaler with 1.9 or 2.2 tires, and it worked fine for the 1/6 Jeep, but as I added more scale items, steel bumpers, rollcage, and 2 - 12" dolls, the steering suffered by not being able to steer unless the vehicle was moving. I have not tested it yet because I'm still in the process of the rebuild.
Old 08-27-2015, 06:39 PM
dirtytanker
wouldn't 222oz be the most I need.
Old 08-27-2015, 06:50 PM
Mike Flea
Mike Flea's Avatar
I would say so, but I might be wrong, not knowing your trails and terrain, but also factor in the weight of your vehicle. Most SCX-10's, scaled out and loaded, let's say with a driver and some scale accessories, weigh in around 8 lbs, and that's taken into account wheel weights, and/or maybe beef tubes. 222oz should be fine. The stock Axial AS-3, from the Ridgecrest, is 133oz, and it works real good turning stock 2.2 Ripsaws, as long as you switch to aluminum steering links.
Old 08-28-2015, 12:37 AM
dirtytanker
this video mite give an idea of what terrain we have in NZ https://www.youtube.com/watch?v=EzZLMfGjwuk
Old 08-28-2015, 12:42 AM
dirtytanker
https://www.youtube.com/watch?v=M3mFXG02s2k
Old 08-28-2015, 12:45 AM
dirtytanker
https://www.youtube.com/watch?v=o8tVGbw-zxk
Old 08-28-2015, 12:51 AM
dirtytanker
https://www.youtube.com/watch?v=OGI2Rkb9rwQ
Old 08-28-2015, 08:20 AM
RustedRC
RustedRC's Avatar
That's about the same kind of terrain i run and iv'e lost three 645's. most that run on that type of terrain add weight to help with crawling, preventing it from rolling over and a list of other things for good reason. IMO if you enjoy running these type of RC's (and i know you do) and want to get the most performance from it through DIY things or upgrades. save your self a headache and get a good servo. yes the price is going to be higher but you will be happier when you see that after some wheel/knuckle, beef tube and metal links so and so on your steering won't slow or change in performance as fast as a lower torque servo would.
Old 08-28-2015, 01:32 PM
dirtytanker
I get some weight from the batteries I use 3800mah nickel metal hydride.
Old 08-28-2015, 08:24 PM
RustedRC
RustedRC's Avatar
then the hi-tec will work good.
Old 08-28-2015, 10:30 PM
dirtytanker
hows the hitec HS-5645MG?
Old 08-28-2015, 10:47 PM
dirtytanker
are there any futaba servo that work all so.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
