RC Rock Crawlers The official rock crawling forum right here on RCU. Rock Crawler Trucks Rule!
8x8 MAN KAT1 trial runs
Old 03-21-2016, 04:01 AM
heavyaslead
heavyaslead's Avatar
Default 8x8 MAN KAT1 trial runs
Here is some videos of my new 8x8 rock crawler.
It's the MAN KAT1.
https://youtu.be/eosRnLU-U88
https://youtu.be/OG-hTU0GUIE
https://youtu.be/yT9sANeCzD8
Have to find some more 'challenging' course work soon.
Old 03-21-2016, 04:27 PM
Mike Flea
Mike Flea's Avatar
Nice build, and it appears to handle flat ground very well, not so much over rough terrain, as the first link shows. Does it have leafs or are you running 8 shocks?
If leafs, you might consider running 1 leaf per wheel, if shocks, softer springs or thinner oil. Doesn't appear to have much flex, to keep tires on the ground.
Old 03-23-2016, 04:12 AM
heavyaslead
Hello Mike
It uses the stock springs and shocks. The shocks do need some breaking in as they were pre-assembled and a bit sticky maybe from the O-ring fit tolerances. The oil is a fine oil already and wicks over everything when opened.
Old 03-23-2016, 04:16 AM
heavyaslead
Since it is an accurate representation of the real KAT, don't expect it to perform on the level of most rock crawlers.
Otherwise I would widen the footprint for sure, as its long body can tend to roll if not approaching obstacles correctly.
Old 03-23-2016, 01:39 PM
RustedRC
RustedRC's Avatar
Looks good to me. the full sizes weren't the best at side hilling. too long for that.the longer you run it the better at judging the approach angle.
i like the sniper rifle on the cab.
Old 06-05-2016, 06:05 AM
heavyaslead
Beach Video for your enjoyment!
https://youtu.be/bedrVgAJB44
Old 06-05-2016, 07:46 AM
RustedRC
RustedRC's Avatar
great video man. that cannon trailer is way cool. the sand is so white it looks like snow at first. when you headed for the water i was like noo not salt water. lol.
Old 06-06-2016, 05:05 PM
Mike Flea
Mike Flea's Avatar
Nice beach run!, where did you find the artillery piece?
Old 06-08-2016, 04:24 AM
heavyaslead
Long Tom is a world peacekeepers toys 18th scale.
Looks a bit smallish to the 12 scale MAN KAT1 but saves lots of scratch building!
