BEST CRAWLERS OUT THERE
#51
Banned
MA
RE: BEST CRAWLERS OUT THERE
no its on ebay, the guy that makes them is incredable, he builds them all different so not one is alike, he is a GENIOUS!!!, but it aint a crawler so it dosnt apply here
#55
IL
my trucks will never come close to what i have seen posted here in this forum but i will share nontheless. i love making and running electric CRAWLERS, they perform in such away that nitro just can't compare or stand up to. anyway heres a pic tell me what you think..............
#56
IL
the two of these trucks have Novak powerplants- TXT-1 running the HV and TLT-1 running the 5800. my only problem is with the TLT-1 every time i pull the trigger the front wheels spin like krazy.[:@]
#58
FL
ORIGINAL: garynjr
You can actually run a motor under water.
An unsealed motor would develop a number of problems:
- rust and corrosion when you return to air
- break-down of anything water-soluable fibre insulators (if any)
- voltage leak in anything other than de-mineralized water
- leaching of lubricants
- attacks by large octopuses
Okay, I made that last one up.
#59
Banned
MA
really?!?!? sweet i guess i odnt have to worry about octopuses then........and on that TXT the body is WAY WAY WAY to high, other than that, cool
#61
ORIGINAL: Balact Man
#63
IL
omg ive never seen those rock crawlers before! those look totally diffirent from any ohter rc truck. how much does it cost to convert to one of those?
#64
IL
ORIGINAL: Cummins
Have you locked the diffs? I don't have a TLT-1 but apparently that just makes it wheely rather than spin.
well funny you should mention locking diff's and all. i locked the txt-1 with bubble gum and it works great. however the tlt-1 has the strangest center diffs i have never seen before so i'm not sure how to lock the center diff. until i figure it out locking the f/r diff won't solve my problem..........[&o]
#67
IL
ORIGINAL: fitzy121
check out pic to lock center diff on TLT
#68
PA
Balact Man, I would not recomend bubble gum to lock your diffs. and also if you do a search on locking the diffs on your TLT you will find there are many threads on that here.
You shouldn't just screw it down hard beause you will just strip it anyway. Some people use small screws to screw the plats together or you can use jb weld or Hot glue. Just be sure that it is even and ballanced. You should lock your front nd rear diffs by using the method where you take one of the cone type gears and flipping it to the other side. It's listed somewhere in the Rock crawling section. do some searches... Hope that helps...
#69
Fitzy that is one mean TLT!!!! How much money went into that? I was thinking of getting one but that looks like £500 upwards!
EDIT: No cussing please. Thanks. // Studysession
#70
IL
ORIGINAL: garynjr
#71
i tightened the scew, stripped it and then i drilled 4 holes in it, took 4 screws and than i screwed it together, now i'm able to make wheelies!!!! (19 turns....)put spacers in one end of the car because it leaned to much, i don't lock the other diff's cause it is my basher
