Help me spec out a Clod Buster set-up....
Hey all. I've wanted a clodbuster since they first came out. I'm thinking of putting together a Clod package to get me started. I was wondering the following:
Can I use my Novak Explorer II ESC with the Clods 2 motors?
What size and how many of each bearing do I need to get the clod completely bearing'ed up?
What is the cheapest oil filled shocks to get to replace the friction dampers? How many do I need?
What kind of run times can I expect with the Novak Explorer and a 3000 matched NIMH pack?
FL
RE: Help me spec out a Clod Buster set-up....
yes but dont expect a high speed truck wired in series with stock motor
Four 5 x 8 Bearings Sixteen 6 x 12 Bearings
I think the associated maxx upgrade shocks are a pretty good deal for aorund $60
Not sure I got 15min out of my clod on 17t series motors or a 3000mah pack
Thanks for the reply. I don't want to go super fast but need a little excitement in my life.....What can you suggest to improve the speed? New motors? Different ESC? 7 cells instead of 6?
FL
I for speed I would deffientley upgrade to a esc that can handle dual paralle motors(ie Super rooster or other) you will pretty much double your speed.
Another thing to upgrade owuld be the motors I would suggest Magnetic Mayhems(22t) they combine both speed and tourq. for one awesome motor.
I run both 14t, 17t and 22t motors depeding on what kind of course.
