CheroKrawler
CheroKrawler
This my attempt to make a scale version of my Cherokee:
Used my TLT-1 (very ruff...still have to clean it up). Fabb'd a tube frame and skinned it.
Be kind, it's my first total RC fabrication!
PA
RE: CheroKrawler
ORIGINAL: supernova803
Xjk9bar1, how is the P2k2 working out in that crawler? I was thinking about putting some in my crawler.
RE: CheroKrawler
The CheroKrawler is under a total redsign -
New tube chasis w/ 3/16 tubing to reduce the weight. Wheel base will be around 13" and the center clearance will be around 3.5".
EMAXX tranny w/ 55t Lathe and 9t pinion. I haven't decided on driveshafts, it's either going to be Traxxas sliders or the Jugg U-joint propeller type. I was going to use some REVO's but I think the wheel base will be to short.
And the Super rooster ESC so I never have to worry about it again.
RE: CheroKrawler
Again, I based it of my XJ...an old version!!! (Lame Windows Paint Pic's)
This a mock up with the top half of the chasis to double check everything is in scale (the battery was only used to hold the front half down).
The final version should look something like this
Joe
Joe
