tires question
MN
i recently bought a clodzilla 5 and wanted to possibly put some new tires / rims on it and was wondering what i would need to run these. [link=http://rc4wd.com/shop/product_info.php?cPath=18&products_id=962]K-Rock Tires[/link]. Right now in the real crawling world, these tires are being used by most pros so thought it would be cool to put them on a r/c crawler. i just need to know if i need to buy hex adapters and what rims? thanks
EDIT: ok i didnt read full, they fit on t/e-maxx rims so i guess i just need to know where i can find an adapter for clod drive to t-maxx hex.
Yes you need hex adaptors, those are maxx tires. I'd get the adapters from rcalloys.com, & get what ever Maxx sized rim you want. Although, they look cool they don't performe the best. You must soften & cut them to get them to work good.
MN
hmm always hard for me to decide between having the best performance over trying to keep it realistic. so maby ill go with the moabs or something.
ok maby im dumb too but im having a hard time navigating that rcalloys site and cant seem to find the adapters.
The K-Rocks will work. But you need to soak them in a bucket of WD-40 or deisel fuel to soften them up. Then you cut every other side lug off. Then you can either cut every other center lug off or just cut the center lugs so that the voids between them is bigger. The moab is a great tire also. They come to life when you narrow the rim about an inch.
MN
hmm well i dont really want to mod the k-rock because then it would look like a different tire. so as of now i guess ill just wait untill i get my truck here and can play with what i want.
and since ive always been curious, how do you narrow rims without really losing a lot of strength?
One easy way is to cut off the outer bead, then put your tire onto the inner bead.
Here's a good tech on how to narrow stock clod rims.
http://utrcrc.com/tech.html
MN
anyone know where i can find a cheaper pair of maxx sized bead lock rims? dont really feel like shelling out $100 for a pair of aluminum rims. or even if not bead lock, just some ones that look like micky tomson outlaws?
