juggernaut-2 bild up
WA
This is my juggernaut-2,let me know what you think.All ESP,Team juggular kit,Wide ride kit,Duel titan motors,Futaba attack-4 chanile for 4 wheel stearing,full ball baring kit,2 superduty bodys,piggy back shocks,duel 7.2 volt 3300 mah batterys,esc powere max speed-controller runing 14.4 volts,This is were i need help,I can not keep the stock drive lines together they bust at the u-joint's.Hase any one have this problem[:@] if so can i get a drive line that will hold up?The drive lines last me about 8 to 12 run's not long.I will try to post pictures,the truck is dirty because i use it.I have not used my camra yet.Please post your modifed drive lines if u have a fix for this.thanks
