can TLT-1 really crawl??
Can you get the articulation , ground clearance and gear reduction out of a TLT to be a decent crawler?? Are the drive belts a disadvantage?? Ive been outta rc cars for a while and want to build a rock crawler , I need some direction! Seems alotta what I read involves clod axles and a buncha my $$. Thanks
My Feedback: (18)
Mine is completely stock right now, it has the articulation to crawl, but the COG sucks. Ground clearence could be better, Mne has right at 1 1/2"s in the middle and a little less in the front and rear.
I just insalled another servo for rear wheel steering, and am going to smaller cells (4/5 SubC) so Im hoping that will help lower the COG.
For the grond clearence problem, I'm wanting to stretch it out a bit (maybe 2"s total, which would put it at 1/10 scale), get the wheel wideners, and run ST wheels with the masher 2k ST tires. That will raise the ground clearence about 3/4" all around.
ON, CANADA
CHECK out the BULU 2 chassis.. it has like 3 - 3.5 inches of ground clearence.. and it has a lower center of gravity.. people use a stampede tranny or a losi xxxt tranny..
the belt drive may skip, im not sure as i havent got my TLT yet..
www.rccrawler.com has good info on making a tlt-1 to a tlt crawler.. check out Newbie Crawlers, or Smale Scale Crawlers.. i forget which one...
Thanks , that place had all sortsa good info! I think the TLT is just what Im lookin for , seems alotta other people likem too.
If stretchin it out 2" makes it pretty much 1/10 scale what scale is yer other rigg?
Im really likin everything I here about the TLT , except for the possibility of a belt jump. Guess Its not a problem untill you really strain it , I guess Ill see what others concider extream. Aneyway thanks for the help
My Feedback: (18)
ORIGINAL: [email protected]
I guess it would be like 1/7th? The body on it now is a 1/10 body, and as you can see the wheel wells are a few inches off.
BTW I was wrong about the 2" stretch making it 1/10 scale. I was thinking its stock wheelbase was 9"s but I measured and its like 7 1/2" so the stretch would need to be 3"s+ to make it 1/10 scale.
That is awsome , I like how you can lay it on the side of the wheels and it dosent flip over.
I would love to build somthing just like that , Its perfect!
I kinda like the smaller size. I keep thinkin it would be alot easier to find stuff to wheel on , a bigger truck requires bigger obsticals.
Do you run the pede trans to get more gear reduction or to get away from the belt? Why did you pick the pede and not one of the others I keep hearing about? Do you have to custom make drive shafts to couple the pede trans w/ the tlt axle? Sorry bout all the ?'s Im still catchin up! Thanks
My Feedback: (18)
I think most people use an aftermarket tranny so they can chop off the bottom part of the chassis and get more center ground clearence.
I havent had any belt problems with my stock tranny.
OOhhhh , never thought of that. I guess youd be relocating lower links and shocks then too , right? Do you know how much ground clerance you can gain by chopping the lower parts the frame? thanks
ON, CANADA
YES.. i got my tlt today.. it is stretched to a 12" wheelbase.. 4WS.. stock drivetrain that hasn't skipped.. i just locked the diffs.. front, rear. and middle was JB welded... it has 2.75" ground clearance.. i was crawling alrite without the diffs locked.. so tomorrow shall be even better.. i will post pics ASAP..
Kewl !! Im looking for the cheapest place to get one , Id like to order one ASAP but dont wanna spend more than I got to. Ive seen em from $87 to $125. Aneyway good luck w/ yours , sounds kewl
My Feedback: (18)
I got mine for $79.95 at Ultimate Hobbies. It took what seemed like forever to get here (more like a week and a half or so), but for the super low price it was deffinately worth the wait
http://www.ultimatehobbies.com//p609.html
I just cant beleive these TLT's are so freakin cheap, I'm contemplating ordering another to keep stock (well stock size anyways) since I'm gonna be converting mine to 1/10 scale.
$79.95 w/ free shipping!!! Done deal , Im ordering one tomarrow!! I am also surprised at how cheap they are. Dont think their gunna get much cheaper any time soon seeing how popular they are! Thanks for the link , I cant wait
OK I looked all over and cant seem to find anything about the bulu frame or a tsc , all I keep seeing is Tamiyas carbon fiber frame. Seeing as theirs really not much to the frame I was thinking of making my own. If It's not to much trouble mabey you or someone can point me in the direction of these frames , Id appriciate it! Thanks
ON, CANADA
ORIGINAL: JasonInAugusta
Go to rccrawler.com for bulu info.
yeah www.rccrawler.com
http://www.rccrawler.com/forum/showt...2&page=1&pp=20 bulu chassis for sale..[8D]
all right.. here's some pics of my TLT.. i just went to a rock pile today and it looked totally uncrawlable.. and wow was I ever wrong... the tlt was extremely impressive.. crawling everything.. I will get pics next time i go..
pics from yesterday
I looked their and cant find anything about it , or anything alse! Im not that good w/ the computer so that might have somthing to do w/ it
Ill keep searching thow , thanks
Yeah I finnaly saw this bulu frame , thanks! I just ordered my tlt today , once i get it i wanna see what it would take to make my own frame. I like the bulu frame but I work at a machine shop and might be able to make my own and save the $$ for other stuff. Either way thanks for the link
