Custom Clod Chassis-Homemade UPDATED PICS
ON, CANADA
Hey... i recently finished my homemade clod chassis. I havent tested it yet as I just JB welded the diffs today, so tomorrow will be the test day. This is my first time making a custom chassis so let me know what you think. Post any suggestions or comments...
Made from a street sign. 1/4-20" allen key screws 3" long, 1/4-20" lock nuts. 4-40 allen key screws 1.5 or 2" long, 4-40 lock nuts, aluminum tubing, brass tubing for top link mounts mounted with body clips. Let me know what you think....
Some specs:
WB - 18.5" but adjustable to be longer or shorter which will increase or decrease the center ground clearance.
Ground Clearance - 5.5"
NEW PICS AT BOTTOM OF THREAD
Some specs:
ON, CANADA
no.. it isnt 4WS... but I have all the parts needed.. i just need to install them and put in a servo and Y harness or go with a 4 channel radio like my TLT...
thanks for the reply
ON, CANADA
yeah... i mounted it somewhat closer to the front rather than having it centered... just for a bit of increased traction...
i have also changed the rear ball links to traxxas ones...
It looks like you'll get plenty of travel that way. I like the way the side plates of the chassis look, it appears to sort of contain all the electronics and add some protection. Sweet.
ON, CANADA
thanks...
I changed the rear link ball cups to traxxas ball cups because I broke one and the store didnt have that same size... all i need now is some type of skidplate... Im thinking of plexi-glass or something... maybe some eavestrough and cut it to size then use the chassis strengtheners (the large bolts near bottom) to bolt it on... I also need some lathe motors because with my 3000 and 3300 batteries.. i only get about 15 mins of runtime...
I will post some pics of articulation soon and some other pics of "just on the rocks"
ON, CANADA
Here are some new pics... pictures of articulation, on the rocks, and step by step stair crawl (the 1st step is about 10" increase from ground)
ON, CANADA
thanks..
yeah... its got some crazy articulation...
I had to move the upper links because the axle was on an angle and the motor kept getting stuck... I then tested it and could crawl up a 5 step staircase... it was awesome...
Instead of moving the links, i could have made longer ones.. but the hobby shop is closed (of course). i still may make longer links and take out the method i have now... although it is extremely capable... but I think it will be the same with longer links instead of an aluminum extension...
