building my own clod chassis
ok im building my own custom clod chassis cuz the i dont like nun of the ones you can buy built im going to build a whole tubular chassis im going to use five feet of aluminum tubing on this and its going to be about 17'' long and 5'' wide and 7'' tall what do you guys think i need help on this pls thanx peace.
My Feedback: (34)
I'm planning on doing this too. Do you have any soldering experience? You need a soldering iron, solder, solder flux will help alot.(flux is alot easier to use if using a torch.)If you can't solder yur screwed. It takes a while to learn. I started by soldering togeter some 1/16th inch wiring into shapes. If you use an iron make sure you heat the part your soldering before you apply solder. Buy some extra tubing incase you screw up. Also you need something to bend the pipe. I my have responded too late, so if you already made it and it worked out, tell me how you designed it, kuz I gotta build mine. Hope this helps.
MN
