ORCRC's Nylint 1/18 ($40 WalMart) Stock Crawler Comp
#78
My Feedback: (34)
RE: ORCRC's Nylint 1/18 ($40 WalMart) Stock Crawler Comp
I bought one last week, the throttle wasn't responding. I did everything that coulda fixed the problem, but it still didn't work so i returned it and decide to go to lhs and gat new batts.
#79
IA
Hello today I bought a jeep one and on the second battery run the rear axle low gear started slipping. I opened it up and what connects the last planitery gear to the gear that ingages the axle is slipping. I think that is it because I bent the thing a little to help it and it did help alittle but it still slips.... Is anyone else experinceing this? if so what did you do to fix it? thanks a lot... woody
#82
IA
well now since I opened up the transmission and put it back together it is really hard to turn and the motor can barely turn it... the rear wheels shut off way before the fronts when letting off the throttle. Am I the only one expirinceing all this trouble or has some one else had all this trouble too? Any help is much needed thanks
#83
My Feedback: (21)
MI
Thats why I'd return it.. Your chances of that happening again are probably slim.. not to mention that sounds like a defect from the manufacturer (covered under warranty) so unless you want to send it back to them and wait weeks, I would return it.
-Brandon
-Brandon
#84
SD
Are you guys having trouble with the 1/18 or the 1/6 cause I have not had one problem with the 1/6 and I have been beating the crap out of it for sure...
#85
IA
we are talking about the 1:18 scale ones... I will just exchange it for another one then and hopefully have better luck with the second. thanks
#86
SD
Tell you what if you think the 1/18 does a good job the 1/16 is far better and now I know it is bigger and ect. but it is lower geared and it weights like 30 pounds and the steering is alot stronger ect. very nice rig..
#87
IA
So has everyones 1/18 scale crawler worked pretty good for them? did I just get a lemon? I am exchanging mine for a new one tommaro and would like to hear from anyone with a 1/18 scale one and how long you have had it and what has or hasn't broke... thanks a lot
#88
My Feedback: (21)
MI
Seriously, if you have the money I would upgrade to the 1/6th scale just for the digital proportional throttle.. which means instead of the throttle just being on or off like it is on the 1/18th, you can actually give it a little throttle or a lot of throttle or in between, which is much better for rock crawling..
-Brandon
-Brandon
#89
GA
i bought the 1/18th scale jeep this morning, its been doing great all day. I thinks a great deal for the price.
#90
IA
Same here my second one has been great. I found some rocks for it to crawl on that are "its size" and if it was going to break like my first one it would have. So I must have just got a junk one the first time. I will soon do some painting and customizeing to make it more realist looking. So that will be fun
#91
GA
Well i have a status report on my truck. The third time i run it the front axle quit pulling so i took it back to wal-mart and got another one. I got home with it and right out of the box the rear axle wouldnt pull. This is got to be the biggest piece of crap in the world.
#92
Can someone please tell me if the 1:18 Nylint either model is available near them, and where that would be? I can't find them anywhere I've looked. thanks.
#95
My Feedback: (21)
MI
Yea.. You can't expect something from a department store -- especially walmart -- to hold up forever and be reliable!!! Not to mention product support? The trucks are probably made in ethiopia like everything else from walmart..
-Brandon
-Brandon
#98
My Feedback: (21)
MI
ORIGINAL: mellymel
Heres mine, took off the excess bars!
lol.. I wouldnt really call the "excess" now when you flip your truck your gonna break your windshield and/or seats!
-Brandon
#99
OH
well mine finally broke...my brother and i were crawling at a gravel pit i took a nasty spill and ended up under water the electrics fried...so i have figured out how to rig a steering servo from one of my savage trucks on it,,i need to figure out how to wire the motors install the esc and im good to go...i have had this thing for months and it is a very capable crawler
#100
My Feedback: (34)
The esc in that is a *******. Before I returned mine, i tried to get to it and fix it, and access is hard never mind puttin a new esc in!
