ORCRC's Nylint 1/18 ($40 WalMart) Stock Crawler Comp
#102
RE: ORCRC's Nylint 1/18 ($40 WalMart) Stock Crawler Comp
i think i'm going to have to upgrade the electrics. i had to fix both axles and something happened while i was doing this. I have no control at all now. It won't steer move or anything. I know the batteries are good but can not find the souce of the problem. any ideas??????
#105
check here for mods!!
http://www.rccrawler.com/forum/showthread.php?t=16514
#106
OH
hey jeep guy i used JIA'S thread to modify my 1/18,,,the mods were easy enough to do i just need to get it wired up,,i didnt get the motors wired right the first time
#108
That's a great thread!
The best mods I've done are flipping the rear link over which helped the under-belly clearance a ton, then I turned the tires around, cut 'em, and added lead shot to the fronts for weight.
#109
http://www.rccrawler.com/forum/showthread.php?t=17842
an update on my uhhh"nylint" , well a few parts of it!
#110
i am looking at getting the new bright 1:10 rc crawler. im just wondering if it is anywhere near as good as the wal mart ones?? is there many upgrades for them?? any help/opinions would be great.
OH
no offense but the new bright is junk if you havent bought it yet save your money and buy the nylint,,,just my .02
#119
My Feedback: (21)
MI
Go to ups.com or dhl.com or fedex.com or usps.com and use their estimate shipping tools.. Should give you a relative price. As I recall, shipping to canada is more expensive, and takes FAR longer to ship because its gotta get checked out by 2 different customs services, 2 different shipping companies (IE UPS and UPS Canada), etc etc.
-Brandon
-Brandon
#120
Im gonna try and get one of these little monsters they look like a barrel full of fun im wanting to get into rock crawling i think this will be a good place to start im gonna go with the 1/18th one ... planning on building a chassis this winter.
#121
What types of aftermarket batteries can i use? Can i use the crappy charger that came with it to charge the aftermarkets? I will get a nicer charger sometime, just not now.
If i swap in an ESC, will that give me proportional throttle and steering (But i will have to swap in a steering servo). Not to mention i will be able to use a fulsize remote! The remote on this thing is tiny!
And last. Can someone explain spring clipping. I assume it would give more flex, but is it at the cost of ground clearance? Also, how do you do it? Just clip the last coil or 2 off and let it be?
My Feedback: (325)
Hi, nylint people.. I have been wanting for a while, but my WW didn't have any. I did go to another WW today, and found just 1. Both WW have rc cars and trucks stacked to the ceilings. Her's my question about the freq (radio) All other rc's were labeld
How do I know which frequency this orange jeep (1/6) is on? Most all the other rc's there say 49 or 27 mgz. I want to use my AM 27 mhz transmitter and want to know if it is on 27 and also if the channel can be changed to 1-6? I did read entire post, and see that is 4 different channels, but that doesn't tell me the freq or band? Thanks for input.
Editied for 1/18 scale, no 1/18's at either wally world [:@]
#124
My Feedback: (21)
MI
I dont know the answer, but I'd try Google'ing it. I do know that if you get the 27mhz truck you can change the crystals to 1-6 no problem. However if you get the 49mhz, I'm not sure. I'm assuming that whatever crystal you put in any reciever will make it respond to that channel, but then again you have problems with proprietary parts. Like you can't use JR recievers with Futbaba Radios and such..
Sounds like a trial and error deal to me, and if all else fails you could always mod it and put your own reciever (hobby level) in it..
-Brandon
-Brandon
#125
My Feedback: (325)
Yep, that would be the fix (to put a rx into it) I hope it is 27 mhz, but no telling whether the crystal can be changed. I will open the box maybe if they'll let me. I may just get it anyways, but thought perhaps it was like all those other ones, it seemed that they were either 27 or 49 mhz. Still no menmtion of a particular channel though, thanks for response.
