Just finshed my Nylint 1:18 mod
NB, CANADA
Well here it is what do you think. What a difference over stock. Anybody want to mod theirs like this let me know
I have some tube left I can cut it the
same size I did mine. [Edit]
WV
RE: Just finshed my Nylint 1:18 mod
You get these at walmart.
That's cool I like it, how do the little ones do with the 2.2s? The only think that has kept me from getting one has been the little tires and low axle clearance.
NB, CANADA
Thanks. The modded one is 1000% better then the stock one. Your right stock they have no flex or ground clearance. This mode is pretty easy to do. All you need is the tubes and bigger tires. Everything else on mine is stock. Some people change the electronics to a receiver and speed controller and a real servo for steering. I may do that in time but I am happy with the way it is now. They are really fun if you have the right place to drive them.
NB, CANADA
These are the tires I bought them on ebay. They were really really hard. I soaked them in simple green and rubbing alchol. Then cut some treads off them and they are not to bad now. I think they are off an old black hawk truck.
hey what size tube did u use i just bought one and i want to make mine sit up like that and everything and how did u do it plz reply me back thanks
hey i just got one 1:18 scale and i would like to make it like yours but i dont have any money if you can help me out write back
ORIGINAL: Stein
NB, CANADA
Well you will need the tires of course that is the most costley part. The tube I used is 1/2 aluminum. Send me a self address stamped envelope and I can send you the tubes cut like I used them. You will need expoy too. I use the stock shocks and just moved them to a different location.
I actually drove one of the Nylint's yesterday while I was in California visiting. For $48, it provided a lot of fun. By the way, I drove it without the body on it.
NB, CANADA
the center of the rim comes off. Take pliers and turn it and it will come off. then you will see the screw or nut to remove the wheel.
NB, CANADA
ORIGINAL: mike7290
can you tell me were you got the tubes at and how u put them on what is expoy?
take a look at this link to see how to do most of it, any questions just ask. I made mine longer then the guy in the link.
http://www.rccrawler.com/forum/showt...8&page=1&pp=20
Epxoy is 2 part glue you mix together and it hardens.
NB, CANADA
ORIGINAL: Traxnitrust2.5R
these 1/18 are they worth buying to play around in the house and in the yard not talking serious crawling but are they serious
http://www.rcuniverse.com/forum/m_4278086/tm.htm
i have one of the 1\6 scale one and like it but it would be awsome to mod it up a little. i dont think the tires can be any bigger but i would like to know how u moded the suspension
