Stick vs Tcc Hustler
so the stick design has a bit more ground clearance and probably a lower center of gravity, but would the full suspension of the hustler make up for that with its ease of control? which do YOU think is a better crawler design?
MO
RE: Stick vs Tcc Hustler
The Stick is the current world champion and the chassis that all others are measured against.
Until it's is beaten, it's the top dog.
W/ that said, in certain situations both chassis and concepts are capable of winning!
ORIGINAL: rideicon
what would you choose if you were going to build 1 of these 2 clods?
Either. Both are great trucks.
The best chassis in the world won't do anything for you if you can't drive.
Question is...which do you like better? Tuber with less ground clearance or the Stick with less weight and more GC?
The only reason i wouldnt get a stick is because i like the look of tubers, but if i was competing, i would get the stick.
It really comes down to wich one you like better!
