esc suggestions.
CA
esc suggestions.
Im looking for an esc.
Mamba max is great but dont want to spend that much.
Any one use the mamba 25 or what about the novak crawler.
Any suggestions is appreciated.
ON, CANADA
RE: esc suggestions.
The Mamba 25 is discontinued. The Sidewinder is like $60, has basically all the features of the MM, and can handle anything you would ever want in a crawler besides dual 35 turns in parallel.
You can use any! Just make sure you have reverse. Most run brushed 45-65turn and all ecs can handle this High RPM. even with 6 cell 1500mah you will get long run times. I had a mamba max in mine and ended up putting my LRP out of a RTR b4. Unless you are going to set brake drag and get all competitive go basic (cheap). My opinions please dont bash/Crawl on.
ON, CANADA
